Adding a disc brake rear to a KZ900
  • Kapahulu
  • Kapahulu's Avatar Topic Author
22 Aug 2011 23:36 - 22 Aug 2011 23:39
#471072
I bought spoke wheels to replace the mags on my newly acquired 1976 KZ900 LTD. Don't like 16" rear wheels in particular, to me they scream "cruiser".
Opened up the box for the back wheel and saw it's actually a KZ1000 wheel. Very nice, however it's setup for a disc, not drum. Looked back at the auction, my mistake it says KZ1000 rear wheel. I guess when I looked at the picture I thought it was a drum brake wheel.
Should I convert my KZ900 to disc rear? KZ1000 swingarm and brake arm that's the easy part. The harder part I think is hooking up a master cylinder and a brake pedal to fit.
Has anyone here done this? OR does anyone have a clean KZ900 18 inch wheel for sale?
Thanks, Mike
2strokeworld.com
Last edit: 22 Aug 2011 23:39 by Kapahulu.
  • mtbspeedfreak
  • mtbspeedfreak's Avatar
Re: Adding a disc brake rear to a KZ900
23 Aug 2011 01:26
#471099
Depending upon how much money you are willing to spend, you could get a Lester rear wheel. 18" and fits a drum brake.
2000 ZRX 1100
1976 KZ 900- Daily Driver
  • Kapahulu
23 Aug 2011 01:30
#471101
I am switching from mags to spokes. Lester's are nice, however I like the spoke wheel look better.
2strokeworld.com
  • mtbspeedfreak
23 Aug 2011 03:14
#471114
Oh alright, I had it opposite. If you had the original mag wheels (ie. Morris Mags), make sure to hang on to them. They're rare- only appeared on '76 LTD 900s.
You can get a drum hub and lace it to whatever wheel you want. You might be able to (but don't quote me) disassemble the KZ1000 rear wheel and lace it to a Z1/KZ900 drum hub.
2000 ZRX 1100
  • wireman
  • wireman's Avatar
23 Aug 2011 05:10
#471118
youre ltd should already be set up for a rear disc B)
  • Kapahulu
23 Aug 2011 16:26
#471189
This LTD definitely has a drum on the back. Is it original? I don't know. The last owner had the bike for 15 years and changed lots of things.
2strokeworld.com
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
23 Aug 2011 16:29
#471190
Yeah, maybe you have a KZ900 not LTD?
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • mtbspeedfreak
23 Aug 2011 16:34
#471191
Didn't '76 KZ900 LTDs have drum rears?
2000 ZRX 1100
  • mtbspeedfreak
23 Aug 2011 16:34
#471192
Either way, post pics!!! :lol:
2000 ZRX 1100
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
23 Aug 2011 16:36
#471194
mtbspeedfreak wrote: Didn't '76 KZ900 LTDs have drum rears?
No.
1975 Z1 900
2004 KX125
  • otakar
  • otakar's Avatar
23 Aug 2011 17:04 - 23 Aug 2011 17:13
#471199
The 1976 KZ900LTD came OE with rear single disc and dual front disc brakes mounted on 7 spoke aluminum wheels. 19" front 16" rear. To mount spoke wheels 19" front and 18" rear and rear disc, the wheels from a 1978 KZ1000A would be required. To convert a bike that was OE drum equipped in the rear to disc requires extensive modifications, including some welding. To utilize a 18" rear drum equipped wheel only requires the wheel from a 1973-76 Z-1 or KZ900. If this bike was equipped with a rear drum brake it never was a LTD. The frame on a LTD would start with the # KZ900B-******. If it was a KZ900 than the frame # would be Z1F-******
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 23 Aug 2011 17:13 by otakar.
  • wireman
  • wireman's Avatar
23 Aug 2011 19:28
#471222
you could use wheels from a 77-78 kz1000 A series bike,750 twin rear disc/wire wheel might work also B)
