rear axle torque
  • jonnybravo
  • jonnybravo's Avatar Topic Author
  • Banned
  • Banned
rear axle torque
20 Aug 2011 09:50 - 20 Aug 2011 13:19
#470269
I have a gs 1100 swing arm on my bike (Z1), I torque to spec but realized a over tightening issue, I have loosened up, metal properties ??? steel vs aluminum ??? what would be the norm ???
ok let me clarify
I tightened by feel , too loose
I tightened to spec 93 ft lbs, too tight
Last edit: 20 Aug 2011 13:19 by jonnybravo.
  • bountyhunter
  • bountyhunter's Avatar
Re: rear axle torque
20 Aug 2011 15:14
#470350
If you mean the rear axle nut, on my 750 the spec is around 100 ft-lbs. On mine, it's all steel in that assembly no aluminum I know of.
  • otakar
  • otakar's Avatar
20 Aug 2011 15:16
#470351
I have the same swing arm and I just tighten it as tight as I can get it with a Box End wrench. No reason to torque it.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • jonnybravo
  • Banned
  • Banned
20 Aug 2011 18:54
#470433
thanx guys, I wondered about that, B)
