Fork question
  • jramsey89
  • jramsey89's Avatar Topic Author
Fork question
20 Aug 2011 02:50 - 20 Aug 2011 09:35
#470219
I have a wrecked kz550A that I'm trying to get going for a friend and the forks may be bent, if they end up being bent, are the forks for the 550A the same as the ltd? It seems like there's a lot more ltd forks on eBay than standard forks. If anyone knows what years are interchangeable that would help too. Thanks.
Last edit: 20 Aug 2011 09:35 by jramsey89.
  • jramsey89
Re: Fork question
20 Aug 2011 09:40
#470264
Also, if the forks are different, are different will the triple trees work from an ltd? Thanks again.
  • martin_csr
  • martin_csr's Avatar
Re: .
20 Aug 2011 10:45 - 22 Jan 2013 04:53
#470282
Last edit: 22 Jan 2013 04:53 by martin_csr.
  • jramsey89
Re: Fork question
22 Aug 2011 19:31
#470991
ok thanks, i guess i will get the triple trees for an ltd and if the forks are bent i will have to look a little harder.
  • martin_csr
Re: .
23 Aug 2011 09:24 - 22 Jan 2013 04:52
#471138
wrong info
Last edit: 22 Jan 2013 04:52 by martin_csr.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
Re: Fork question
23 Aug 2011 11:46
#471159
With conventional forks all you need to do is make sure both sets of forks use the same seal I.D., then they will fit in the clamps. Check the axles and wheel bearings too.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • martin_csr
Re: .
23 Aug 2011 12:49 - 22 Jan 2013 04:44
#471164
Last edit: 22 Jan 2013 04:44 by martin_csr.
  • jramsey89
Re: Fork question
29 Aug 2011 23:55 - 29 Aug 2011 23:56
#472722
thanks for the info guys, not sure if the forks are even bent yet. It really looks like they just move at the top (as if the triple tree clamps were loose and one fork moved forward while the other went back) As for the trees, the upper clamp actually broke at the stem when I wrecked it so I'm not taking any chances there and just replacing the whole triple tree.
Last edit: 29 Aug 2011 23:56 by jramsey89.
  • martin_csr
Re: .
30 Aug 2011 09:53 - 22 Jan 2013 04:44
#472792
  • jramsey89
Re: Fork question
31 Aug 2011 14:22
#473271
yeah, i have seen several trees. I'm just hoping the rest is good because I don't want to fork over the extra cash... (lame pun but I couldn't resist)
