brake lines are dangerously split
- cobura
- forever 2 wheels
19 Aug 2011 17:20
My brake lines are dangerously split, I fear my bike has become a potential deathtrap. I heard that the local napa shop can cut brake lines to length, so I ripped off the old brake line and brought it there. Unfortunately, they dont do banjo bolts, and the hose diameter doesnt fit their machine.
Does anyone know where I can find a company that sells brake line cut-to-length? I need a custom length because my handlebars are significantly shorter than stock, so i need about 1 inch shorter than stock length. ALTHOUGH, is there a tool I can buy that would allow me to make the lines myself? There are no custom bike shops around my area and I am out of options.
1979 KZ650B3
- mtbspeedfreak
Re: brake lines are dangerously split
19 Aug 2011 18:24
Z1 Enterprises has a few options.
Goodridge SS braided hoses are what I use- absolutely no complaints (other than the $20 premium for the black color over the bright bare SS).
2000 ZRX 1100
1976 KZ 900- Daily Driver
19 Aug 2011 18:25cobura wrote: ...anyone know where I can find a company that sells brake line cut-to-length?....
Z1 Enterprises has many different lengths, fittings, etc.
Click > www.z1enterprises.com/SearchResult.aspx?...eyWords=brake%20hose
- mtbspeedfreak
19 Aug 2011 18:30Patton wrote: Z1 Enterprises has many different lengths, fittings, etc.
...and service with a smile :lol:
2000 ZRX 1100
- MFolks
19 Aug 2011 19:54
Brake Lines
www.galferusa.com/html/ss_line_kits.html
inlinetube.com/
www.spieglerusa.com/cfm/brakelines.cfm
www.helusa.com (the brand I'm using on my 1982 GPz 1100)
www.russellperformance.com/metric_two-line.shtml
www.goodridge.co.uk/motorcycle-brake-lines/kawasaki.htm
inlinetube.com/
- hocbj23
19 Aug 2011 21:59
Using Speigler--teflon coating in many colors over braided stainless.Good stuff.bj
- steell
20 Aug 2011 06:35
A hydraulic hose shop should be able to make the lines for you, but Z1 would probably be cheaper.
- jeffasaki
20 Aug 2011 08:15
if you ride without brakes you get what you deserve
please get your shit together
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- Old Man Rock
20 Aug 2011 09:43
No need to say more...
Attachment SPeiglerBrakeLines.JPG not found
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- draboo
- zzz
20 Aug 2011 12:37
I just had 4 lines made for my 1100. They were 30.00 each, which I thought was reasonable.
1983 KZ1100D Spectre shaft
- cobura
- forever 2 wheels
22 Aug 2011 11:03
Woah those spiegler lines are nice! And, dont worry, I do "have my shit together". Bike has been de-comissioned ever since I discovered the crack in my line.
1979 KZ650B3
The following user(s) said Thank You: mtbspeedfreak
- mtbspeedfreak
22 Aug 2011 20:25cobura wrote: Woah those spiegler lines are nice! And, dont worry, I do "have my shit together". Bike has been de-comissioned ever since I discovered the crack in my line.
Thanks... there are a lot of the crazies out there.
2000 ZRX 1100
