Rear master cylinder diaphragm
  • Redox6022
  • Redox6022's Avatar Topic Author
19 Aug 2011 07:04
#469984
Does anyone know the purpose of the rubber diaphragm that goes into the rear master cylinder with a kz with disc brakes? I noticed it when I was bleeding the rear, it seemed I got more fluid flowing through the reservoir if I took it out. How do you re-install it if the reservoir is full of fluid? Drain the excess and just push it in? Thanks
1981 GPz550
  • KZ_Rage
  • KZ_Rage's Avatar
  • Kentucky Bourbon Barrel Ale
Re: Rear master cylinder diaphragm
19 Aug 2011 10:39 - 19 Aug 2011 10:41
#470005
Every brake reservoir has one, most act partly as a seal. I believe they are meant to allow for changes in air volume as the fluid goes in and out or when the level drops from pad wear without outside air directly contacting the fluid since it is hygroscopic.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
Last edit: 19 Aug 2011 10:41 by KZ_Rage. Reason: left out stuff
  • Redox6022
21 Aug 2011 00:28
#470550
I'm an idiot, that's exactly what it is, but what had happened is it got pushed down into the bottom of the plastic cup. I took it out and pushed it back to shape.
1981 GPz550
