Fork/Motor Oil/ATF
  • Shoey949
  • Shoey949's Avatar Topic Author
Fork/Motor Oil/ATF
13 May 2006 10:41
#46989
The nearest store which sells fork oil is a 45 minute drive away so I wanted to know if I could use ATF or motor oil. I know this has come up several times and I have looked at the archives but nobody seems to give a clear answer if motor oil or ATF will deteriorate or harm the seals or the forks?
Thanks,
Nate
'83 GPz550H2 w/'81 GPz 550D1 engine
Dynojet Stage 3 kit, MAC 4-1, UNI Pods, DYNA coils and plug wires, WG ignition mod
Grand Rapids, MI
  • steell
  • steell's Avatar
Re: Fork/Motor Oil/ATF
13 May 2006 15:22
#47038
Nope, won't harm the seals or the forks, may not work as well though. No harm in trying it, and if it don't suit you, you can always change it later.
