79 KZ1000 ST E1 throttle grip installation
- kzboy
17 Aug 2011 18:10
Should the throttle grip be installed all the way on untill it bottoms out on the handle bar? Also what is the hole for on top of the handle bar where the starter buttom assembly goes.
- mtbspeedfreak
Re: 79 KZ1000 ST E1 throttle grip installation
17 Aug 2011 19:18 - 17 Aug 2011 19:19
It should be close, but the handlebar should not be touching (and binding) against the inside of your grip end.
The hole on the top of the bar aligns with a post on the starter button assembly to make sure it stays put and doesn't rotate when you twist or let off the throttle forcefully.
2000 ZRX 1100
1976 KZ 900- Daily Driver
Last edit: 17 Aug 2011 19:19 by mtbspeedfreak.
- kzboy
17 Aug 2011 20:03
thanks! thats what I thought it was for.
17 Aug 2011 20:12
Be sure to lube where the tube rotates on the handlebar. White lithium grease works well there. Ed
- KZ_Rage
- Kentucky Bourbon Barrel Ale
17 Aug 2011 20:52
If you haven't already you should try a set of Oury's, I found them to be the best I've had on my shafty for all day riding, corner carving, anything really.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
1984 KZ550F2 SOLD!
- kzboy
20 Aug 2011 18:16
Does anyone know if NOS kawasaki throttle cables PART NUMBER 54012-150 fits all bikes that use this part number or is the same part number used for different models. example PART NUMBER 54012-150 KZ1000a is diffferent then PART NUMBER 54012-150 KZ1000 st e1?
- KZ_Rage
20 Aug 2011 21:21
It will work on your bike if that is what you're asking, the cables are 54012-150 and 54012-149.
AS far as different 150 part numbers, then the answer is no, they are the same the have other cables like 54012-1504, etc but those aren't for your bike.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
1984 KZ550F2 SOLD!
