kz100 Rear wheel spacers
  • kzed1972
  • kzed1972's Avatar Topic Author
16 Aug 2011 18:43
#469437
Have a 1978 kz1000, looking for advice. I have an aftermarket swingarm one inch wider than stock. What spacers should I get? Starting from scratch. Rear wheel is a 16" with a 160 tire stock 78 ltd mag wheel
  • wireman
  • wireman's Avatar
Re: kz100 Rear wheel spacers
16 Aug 2011 19:27
#469439
If its 1" wider than stock id have 1/2 wider spacers made for each side.on the right side of bike youll need the wider spacer between brake caliper/bracket and swingarm,not between caliper and wheel B)
  • wireman
  • wireman's Avatar
16 Aug 2011 19:43
#469446
youre running a 160 tire on a stock rim? :blink: normally a 130 is about the max to run safely on a stock wheel
  • kzed1972
16 Aug 2011 19:53
#469450
I bought it like that. Sure it came of a dragbike.
  • mtbspeedfreak
  • mtbspeedfreak's Avatar
16 Aug 2011 20:35
#469454
Yeah, that's awfully wide. I'd seriously rethink that...
2000 ZRX 1100
1976 KZ 900- Daily Driver
  • kzed1972
17 Aug 2011 09:38
#469518
Is it possible the some stock mag rims were wider?
  • wireman
  • wireman's Avatar
17 Aug 2011 15:09
#469555
do you have a picture of tire/rim?
