Is this a tubeless tire wheel?
- badrhino
14 Aug 2011 20:25 - 14 Aug 2011 20:31
These wheels are on my bike and there are no tubes in the tires. Are these wheels made for tubeless tires?
Thanks!
Thanks!
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Franken Z!
Last edit: 14 Aug 2011 20:31 by badrhino.
- badrhino
Re: Is this a tubeless tire wheel?
14 Aug 2011 20:32
The tire is a bitch to try to get off, it is on there good.
Franken Z!
Franken Z!
- gd4now
- Denco where did you go?
14 Aug 2011 20:55
That looks like a tube rim to me. The non-tube rims have extra ridges in the center area of the rim to hold the bead in place. I have attached a couple of pics the first is a tubeless rim and the second is a tube rim. Hope this helps.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- badrhino
14 Aug 2011 21:29
Oh, I'm sure its a tubed rim also, but just making sure. And to think the morons I bought the bike from used to drag race it like that without tubes in the tires.:S
Franken Z!
Franken Z!
Last edit: 22 Jan 2013 03:24 by martin_csr.
- mtbspeedfreak
15 Aug 2011 03:50
So how crazy would you have to be to TIG weld two beads around the rim to "create" a tubeless tire from a tubetype mag rim?
2000 ZRX 1100
1976 KZ 900- Daily Driver
- steell
15 Aug 2011 09:47mtbspeedfreak wrote: So how crazy would you have to be to TIG weld two beads around the rim to "create" a tubeless tire from a tubetype mag rim?
You would make it immensely more difficult to mount a tire at least.
In addition to having the two ridges, tubeless wheels also have a deeper center section to allow the tire to slide in and clear the other side.
Look at the two pics above and you'll see the difference.
- otakar
15 Aug 2011 10:02 - 15 Aug 2011 10:03
The only time the difference comes into play is when you have a flat. The tubeless is designed to TRY and prevent the tire from coming off the rim when flat. I used to run tubeless tires on tubed rims all the time in the older days, and never had a problem. Heck, at one time bikes used to have rim locks on them to hold the tires on. If you use a tire on a tubeless rim that is larger than specified, than the designation is a mute point anyway. The tire will come of the rim regardless, and a lot of the guys here do that.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 15 Aug 2011 10:03 by otakar.
- steell
15 Aug 2011 22:18 - 15 Aug 2011 22:20The only time the difference comes into play is when you have a flat
If that's the case, then why don't the tube type rims have that same ridge? They do go flat sometimes.
It's really not rocket science, just spend a couple of minutes thinking about what happens when the air pressure gets low due to a leak, and say you catch the edge of a pothole that pushes in the sidewall.
Tubeless tire on a tube type rim may have the bead pushed back with resulting immediate loss of all air pressure. Tube type with a tube, the tube just pushes the tire bead back against the rim.
Is that really that hard to grasp?
Rim locks were never about holding the tire on the rim, they were about keeping the tire from spinning on the rim and ripping the valve stem out of the tube.
Do whatever you like, it's your butt on the line, not mine.
Last edit: 15 Aug 2011 22:20 by steell.
15 Aug 2011 23:56
If absolutely 100% positive that will never ever hit a pothole while leaned over in a curve, with perhaps not quite enough air pressure in the tire . . . :huh:
- otakar
16 Aug 2011 07:10Patton wrote: If absolutely 100% positive that will never ever hit a pothole while leaned over in a curve, with perhaps not quite enough air pressure in the tire . . . :huh:
If that happens, I don't think that a tubless rim will happen much. :whistle: I have clocked close to a quarter million miles between my bikes over the years and never had a problem with wheels or rims that were cast. Only spoked wheels have I ever had a flat on.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- RonKZ650
16 Aug 2011 19:28
Here's what happens when a tire comes off a wheel. This is a 1979 Ford 3/4T van with original wheels. I would bet anything in 1979 these vans ran a tubeless wheel tire? Well this company van has had many a tire on it and it appears a tube type wheel? Nobody has ever told me to use a tube in this wheel. The van has been sitting for quite some time. I came outside one day and the tire had decided to demount just sitting there. That wouldn't be pretty on a motorcycle at speed, actually not in a van at speed either.:lol:
