Fork Cap Stuck
- badrhino
Fork Cap Stuck
11 Aug 2011 20:28
Any ideas on how to get a fork cap out. One of my caps won't come out. I don't have a vice to put it in. Any suggestions?
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Franken Z!
- KZ_Rage
- Kentucky Bourbon Barrel Ale
Re: Fork Cap Stuck
11 Aug 2011 21:23
Sounds like you have it off of the bike, just put the tube back into the triple tree and re-tighten, then try breaking the cap plug free. I always break mine free while still on the bike.
If that was already tried and didn't work then without a vise that's going to be a challenge. I took a strap wrench to make a regular vise a "soft jaw" once to get them out of a set that was already off the bike. Still a pain in the butt to go that route but it worked.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
1984 KZ550F2 SOLD!
- Kidkawie
- I bleed premix
Re: Fork Cap Stuck
11 Aug 2011 21:29
Loosen the upper clamp, not the lower clamp. Pressure on the upper clamp locks the cap in.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- KZ_Rage
Re: Fork Cap Stuck
11 Aug 2011 21:31
Oops, good call Kidkawie, I forgot to mention that I slide them up due to that and so as not to chance slipping and whacking the speedo/tach.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
1984 KZ550F2 SOLD!
- badrhino
Re: Fork Cap Stuck
11 Aug 2011 21:33
Thanks guys, I'm a tard, never thought about putting it back in the triple tree.:blink:
Not that it matters anyhow, I could always put the new oil in after I get the forks back on the bike anyway. Just figured I would try to get them off with forks out.
Franken Z!
Franken Z!
Re: Fork Cap Stuck
11 Aug 2011 23:24Kidkawie wrote: Loosen the upper clamp, not the lower clamp. Pressure on the upper clamp locks the cap in.
You're not kidding! The first time I changed fork oil I thought those caps were welded in. Once I figured out to loosen the top clamp I wrote it in my manual so I never make that mistake again. Ed
- Kidkawie
- I bleed premix
Re: Fork Cap Stuck
12 Aug 2011 10:29
On some bikes, a too tight bottom clamp will affect the mid stroke of the fork, producing a tight spot.
1975 Z1 900
2004 KX125
2004 KX125
