KZ1000 Brake Question
- Sienar1
12 May 2006 11:48
I found a KZ1000 frame in a parts lot locally for $50 bucks... I would love to put a KZ1000 together - But I think this bike had a rear drum brake, I would prefer disk... How do you tell the difference? Can you convert them?:S
KZ1000 Newbie
Post edited by: Sienar1, at: 2006/05/12 14:49
KZ1000 Newbie
- Mcdroid
- Gone Kwackers
Re: KZ1000 Brake Question
12 May 2006 12:46
I'm pretty sure Kawasaki went from a drum rear brake to a disc in 1977. Phrased another way, the KZ900A4/5 had a rear drum brake while the KZ1000A1 had a rear disc. Check the frame triple tree for a VIN and manf. date...it should let you know what you are looking at and the general direction you'll be heading in:)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Sienar1
12 May 2006 12:58
I did look at the tag: it is a KZ1000 A1 1976... I forgot to write down the vin# - I will drop buy and give it another look.
- Pterosaur
12 May 2006 13:08
Yep, it was '77 they went to rear discs...
Y'know, there _is_ another way to look at it....
A drum rear indicates an older vintage. An older vintage translates to a more valuable bike, given a decent restoration/rebuilding.
Having owned both types of rear brakes on a Z and KZs, I can vouch for the fact that if a drum is set up right, it'll lock your rear wheel as quick or if not quicker than a disc. And if you're worried about fading, either you're using your rear brake too much or you're running the Isle of Mann.
A reasonable guess is that Kaw went to rear discs to streamline manufacturing and costs. Take a look at the rear brake rotor - same exact item as on the front.
All things being equal, I'd feel enouraged by the drum rear.
If it *really* bugs you, it's not that big of a deal to convert it - a rear hub and a few other items - I'm _sure_ there's someone around here that'd make that swap...
- Mcdroid
- Gone Kwackers
12 May 2006 13:22
Sienar1 wrote:
You already know enough to be sure it was a rear disc bike. 1977 year model KZ1000A1's were produced starting in late 1976. However, unlikely as it is, it is possible that someone could have retrofit a KZ900 rear hub into a Z1000 frame... :blink: The early model Z1000 rear discs functioned notoriously poor in certain situations.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Sienar1
12 May 2006 13:53
Here is the vin# KZT00A-013532
When I went back to check the vin# the guy let me have it for FREE!:woohoo: Its just a bare frame with no title - but it is in damn nice shape, little rust, no mods or damage... I see Powder Coating in its future.
My first KZ1000 - Im so happy!
- dog pound
12 May 2006 14:00
My 1977 KZ 1000A1 is Disc. Stock.
KZ 1000 Spec sheet,
KZ 1000 SPECIFICATIONS
Price $2899.00
Performance
Standing start ¼ Mile, 12.65 sec – 105.75mh
Engine RPM at 60mh, Top Gear, 3721 RPM
Average Fuel Consumption, 43.3mpg
Load Capacity – 333lb
Max Speed in gears at engine redline
1st – 52.50 2nd - 76.25 3rd - 99.99 4th - 121.12 5th - 137.05
Engine Type – 4 stroke Inline 4 cylinder DOHC 2 valves per cylinder, Air cooled
Bore & Stroke – 70 * 66
Piston Displacement 1015cc
Compression ratio - 8.7.1, full stroke
Carburetion - 4 Mikuni VM26SS, 26mm
Exhaust System - 4 into 2 interconnect or
Ignition - Breaker Points, 2 twin lead ignition coils 3ohms
Air filtration – Disposal able Paper element
Oil Filtration - Disposal able Paper element
Oil capacity – 3.7li
TRANSMISSION
Type - 5 speed constant mesh, wet plate clutch, chain final drive
Primary drive - chain drive, spur gear 97/56, 1.73.1
Final drive - 630 chain 33/15, 2.20.1
Gear ratio overall, 1st -12.08, 2nd - 8.34, 3rd - 6.36, 4th - 5.25, 5th - 4.64
CHASSIE
Type – Mild steel full double cradle, telescopic front fork, Swing arm rear fork
Wheel base, 1505mm
Rake / Trail, 26*/90mm
Brake Front- Hyd disc 296mm rotor
Rear- Hyd disc 292mm rotor
Wheel Front- Conventional Spoke 2.5in
Rear- Conventional Spoke 2.5in
Tire Front- 3.25H/19 4 PR Japanese Dunlap F6
Rear- 4.00H/18 4 PR Japanese Dunlap K87
Seat height - 31.5in
Ground Clearance - 160mm
Fuel capacity - 13.1li
Curb weight full tank- 256.3kg
Test weight- 331.1kg
ELECTRICAL
Power source- Alternator, permanent magnet
Charge - Solid state, Regulator / Rectifier
Head light beam, High / low - 12v, 50/60w
Tail / stop lights - 12v, 8/27w
Battery, 12v, 14ah
Speedometer Error
30 actual 28.6
60 actual 56.2
TAC RATIO = 5.1
Post edited by: dog pound, at: 2006/05/12 17:02
Post edited by: dog pound, at: 2006/05/12 17:04
KZ 1000 Spec sheet,
Price $2899.00
Performance
TRANSMISSION
CHASSIE
Wheel base, 1505mm
ELECTRICAL
Battery, 12v, 14ah
Speedometer Error
30 actual 28.6
60 actual 56.2
TAC RATIO = 5.1
- Pterosaur
12 May 2006 14:03
Shuckey-darns.
Where am _I_ when deals like this happen? :blush:
Hey - I'll give you a skateboard with three wheels, a peanut butter & jelly sammich with only *one* small bite taken out of it (I didn't slobber much, *honest*) and a frog for it...
- Sienar1
12 May 2006 14:17
NO WAY! Its mine, all mine! I was in shock when he said take it... I guess it has been there for a while... the bike was his sons, but it broke down and he parted it out... he was going to make a drag bike out of it but that never happened.
Im going to turn it into a Mad Max Kwaka... I just wanted to make sure that the early 1000s had disk and not drum brakes...
Pterosaur wrote:
Shuckey-darns.
