78 kz1000 ltd
  • mopguy
  • mopguy's Avatar Topic Author
78 kz1000 ltd
09 Aug 2011 23:08
#468106
Restoring a 1978 KZ1000 LTD and now I am stuck as to either paint the frame and keep original frame sticker or powder paint and lose sticker, any advice from the pros will be appreciated. Tony in Toronto,Canada.
  • Kawboy74
  • Kawboy74's Avatar
Re: 78 kz1000 ltd
13 Aug 2011 01:26
#468748
I didn't powder coat my frame,swing arm,triple clamps etc. as if you ever catch a stone and chip it I'm told it can't be touched up and will eventually start to loosen paint around the area. I had mine done by a shop with some type of urethane which seems to be pretty durable. I made an aluminum cover bent to fit around the VIN sticker which saved it when sandblasting of frame was done and it turned out well. a zip tie was used to secure it through the small void behind the steering neck.
Good luck! David
1974 Z1A As original as I could get it
'88 ZX750R braided lines, mostly original
KZ1000 project on the bench
Burlington,Ontario,Canada
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
Re: 78 kz1000 ltd
13 Aug 2011 09:57
#468772
This might help. Roy
z1oc.com/topic/3496726/1/
