Z1R swingarm fit on a GPZ1100B2 frame?
- jcote75
08 Aug 2011 20:49
I have an eye on a Calfab swingarm. It is now on a 78 Z1R.
Does anyone know if a swingarm from a Z1r can be swap on a GPZ1100B2?
Thanks
Thanks
- jcote75
Re: Z1R swingarm fit on a GPZ1100B2 frame?
18 Aug 2011 20:08
Can someone give the mesurements of a z1r swing arm?
- StreetfighterKz
19 Aug 2011 09:41
If the Z1R arm is the same with as all the other 73-80 Kz900/1000 arms then it's 235mm wide at the pivot. Not sure on the length though.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
19 Aug 2011 10:49 - 19 Aug 2011 10:50
the z1r is the same as a any 900/1000 chain drive in length and width.
i am not close to one for several hours.if no one gets back i will try to get some real measurements.
Last edit: 19 Aug 2011 10:50 by 531blackbanshee.
- jcote75
20 Aug 2011 19:22
From what I understand, it would be the same except for the bike that have a brake drum instead of the disk brake.
Am I right?
Am I right?
22 Aug 2011 13:17
yes.
but with a couple minutes with a cutoff wheel and 5 minuntes with a welder,it can be a disk brake or drum brake swingarm :lol: .
there is a different brake anchor tab depending on which it is for.
that shouldn't slow you down :evil: .
- wireman
22 Aug 2011 15:33
just hang a caliper on the bottem side like a sport bike
