Z1 front wheel on a KZ?
  • mtbspeedfreak
  • mtbspeedfreak's Avatar Topic Author
08 Aug 2011 12:30
#467698
What goes in to running a Z1 front wheel on a KZ 900? Do I need to swap the fork lowers in addition to getting the speedo hardware?
2000 ZRX 1100
1976 KZ 900- Daily Driver
  • otakar
  • otakar's Avatar
Re: Z1 front wheel on a KZ?
08 Aug 2011 12:45
#467702
I thought that they were the same?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • mtbspeedfreak
08 Aug 2011 12:48
#467703
No I don't think so- different axels and speedo drives, etc.
I'm wondering if an assembled Z1 wheel fits in KZ lowers.
2000 ZRX 1100
  • otakar
  • otakar's Avatar
08 Aug 2011 12:55
#467706
I know that Kawi used two sizes of axles I am not sure what the transitions were. Just change the bearings in the wheel to match your axle and spedo drive.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • mtbspeedfreak
08 Aug 2011 13:40
#467710
Z1 front bearing kit: www.z1enterprises.com/Wheel-Bearing--Sea...-Z1-KZ1000-2783.aspx
KZ front bearing kit: www.z1enterprises.com/Wheel-Bearing--Sea...900-KZ1000-2784.aspx
I just put new bearings in my Z1 front wheel, but I don't think anything else will swap over. Look at a Clymers manual if you've got one- two completely different schematics for the front wheels.
2000 ZRX 1100
  • mtbspeedfreak
08 Aug 2011 14:30
#467728
Will Z1 lowers work on KZ forks?
2000 ZRX 1100
  • BohicaBob
  • BohicaBob's Avatar
08 Aug 2011 20:40
#467806
Z1 (1973-1975) front fork lowers and spindle is different from the KZ900/KZ1000's. I switched to KZ650 lowers, KZ900 damper rods, and '73 Z1-900 fork tubes with Progressive springs on my '73 Z1-900 because I wanted to use a Telefix front fork brace.
Bet KZ forks will work with Z1 lowers, but the Z1 damper rods leave much to be desired.
  • mtbspeedfreak
08 Aug 2011 21:29
#467834
My predicament is that I have a pair of Lester wheels with a Z1 front hub. I need to mount them on my KZ900 in 10 days before I ride 8,000 miles to Alaska and back. I have the wheel (tire mounted and balanced), just installed new bearings, and rotors.
What's the best course of action?
2000 ZRX 1100
  • kawman66
  • kawman66's Avatar
08 Aug 2011 22:19
#467855
id try and put it on. I belive the axel nuts are the same
75 z1b
76 kz900ltd
76 kz900
76 kz900-1500
77 kz1000ltd
my drinking team has a racing problem
