Front suspension and swing arm
  • maddog702
  • maddog702's Avatar Topic Author
07 Aug 2011 23:39
#467602
Hello I'm pretty new to KZR but I'm looking for some help. I have a 83' KZ750 cafe project I'm working on and I want to put on a more modern front end and rear swing arm. Does anyone know of a new bike that would match up well to a 83 KZ frame?
  • steell
  • steell's Avatar
Re: Front suspension and swing arm
08 Aug 2011 11:43
#467693
There was one model of 83 KZ750 twin (Belt drive), and four models of 83 KZ750 four.
Which model do you have?
  • TexasKZ
  • TexasKZ's Avatar
08 Aug 2011 12:23
#467696
Welcome to the forum. Most any modern forks can be fit by changing the steering stem; that is, use the stock stem in the new triple clams. Some fabrication may be needed, such as new headlight and instrument cluster mounts. If a front end off a naked bike , like ZRX, is used, then less fabricating will be needed. Search this forum and you will find a bunch of threads on front end / fork conversions.
  • maddog702
08 Aug 2011 12:48
#467704
I have a four.
  • maddog702
08 Aug 2011 12:56
#467707
Thank for the reply. The front end is off. I plan on doing a totally new front end. Lights, gauges I just wanted to something more modern and progressive. I wanted to find something that will mount right up to the stock stem.
