1979 kz1000s original Rear Tyre size 4.50-17.
- kzboy
07 Aug 2011 18:46
The original Rear Tyre size was 4.50-17. What does that convert to in todays size 120/90-17?
- wireman
Re: 1979 kz1000s original Rear Tyre size 4.50-17.
07 Aug 2011 19:18
i thought only suzuki was using 17s back then
07 Aug 2011 19:48kzboy wrote: The original Rear Tyre size was 4.50-17. What does that convert to in todays size 120/90-17?
Links to tire size info in FILEBASE:
www.kzrider.com/filebase/doc_download/392-tire-size-conversion
www.kzrider.com/filebase/doc_download/397-tire-info
- otakar
07 Aug 2011 21:12wireman wrote: i thought only suzuki was using 17s back then
Nope, the early KZ shafts (1000/1300) had 17" rims The 4.50 would be a 115/90-17 if there was such a thing. But a 120/90-17 would work just fine. It would only be a couple of MM wider and about as manyMM larger in DIA.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
