GS arm installation ?'s
- sbulla
- 1980 KZ1000 LTD
07 Aug 2011 14:34
Hi guys, I'm in the midst of installing a GS arm on my KZ and, while figuring out what size wheel spacers I need to take up the slack of the wider arm, I noticed that the lower shock mounts will be outboard of the top mounts quite a bit.
I have a set of Progressives with the forked (or clevis) bottom mounts on the way so, I need to know from you that have done this conversion, if the rubber grommets in the mounts will give enough to allow these to be mounted securely at that angle.
Also, just FYI, I measured the length of the two arms when I had them off and, the GS only gains me 1" over the stock arm. I've always heard 1.5"-2" so, I wonder if the '80 LTD maybe had a bit longer arm than some models or there are differences in GS sizes from year to year. I think the one I have was off an '82 1100.
Sonny
Sonny
Now----
1980 KZ1000 LTD (Kerker 4-1, K&N pods, Dyna gray coils)
Gone but not forgotten----
1966 Honda 305 Superhawk
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
1995 HD Sportster 1200
2000 HD Softail
2002 KLR650
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
Re: GS arm installation ?'s
07 Aug 2011 14:40
Of possible interest ---
Click > www.z1enterprises.com/Shock-Mounts-Billet-Aluminum-2043.aspx
- sbulla
- 1980 KZ1000 LTD
07 Aug 2011 15:34Patton wrote: Of possible interest ---
Not much of a place to put that style of mount on this arm. I know there are ways to mount the eyelet style shocks on this arm with a bit of welding but, I have the Progressives coming so, just wanted to see if those that have done it could shed some light on the subject.
Sonny
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
