Air fork link tube KZ1100
  • fergieuk
  • fergieuk's Avatar Topic Author
07 Aug 2011 14:17
#467488
Got a leak in my airlink equaliser pipe(if that is what it is called?) I looked to remove it only to find it doesn't unscrew without removing whole setup. Have put a hose clip temp fix on but am wondering, can I cut it off and make a new link with hydraulic pipe with bolts that turn on each end? Was thinking along the lines of car brake pipe as got a flare kit. And yes I am the king of noshing and making do.
Fergie
KZ1100D1
  • otakar
  • otakar's Avatar
Re: Air fork link tube KZ1100
07 Aug 2011 14:22
#467492
The pressure in the front forks is very low. You don't have to mess with any special tubing. I think that if you cut the tube and exposed the barbs on the fittings, a regular pair of good fuel hose clamps would be more than good enough. a length of fuel line intended for fuel injection would also suffice as the link tube.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
