1979 kz1000 st front brake master cylinder repaint
- kzboy
07 Aug 2011 08:15 - 10 Aug 2011 21:38
whats a good match for the original master cylinder paint on a 1979 kz1000 st front brake master cylinder.
Also how do I remove the piston from the bore?
Last edit: 10 Aug 2011 21:38 by kzboy.
- KZ_Rage
- Kentucky Bourbon Barrel Ale
Re: 1979 kz1000 st front brake master cylinder repaint
07 Aug 2011 11:34
Rattle can or sprayer?
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
1984 KZ550F2 SOLD!
- MFolks
07 Aug 2011 14:13
PJ-1's Fast Black is a good spray paint. If possible, remove the window on the master cylinder so you can bake on the paint. Let it air dry for a day and then use an oven. I bake parts at 300 F for about 50 minutes
- kzboy
07 Aug 2011 16:18
Rattle can is what I'm looking for. What gloss should I use with the PJ-1 and should it be the heat paint?
- MFolks
07 Aug 2011 16:56
The PJ-1 Fast Black is a semi gloss paint, close in matching the master cylinder original paint color.
- kzboy
10 Aug 2011 20:49 - 10 Aug 2011 22:23
I have a MC off of a parts 79 KZ1000 and want to give it a good cleaning. It has a stuck/rusty piston so I'm not even sure if I can get it out or if the bore is good. What would be the best way to clean out the insides that wont damage the window seal.... Brake spray cleaner in a can? I've used distilled vinegar on carbs and it worked great.
Last edit: 10 Aug 2011 22:23 by kzboy.
11 Aug 2011 00:38kzboy wrote: I have a MC off of a parts 79 KZ1000 and want to give it a good cleaning. It has a stuck/rusty piston so I'm not even sure if I can get it out or if the bore is good. What would be the best way to clean out the insides that wont damage the window seal.... Brake spray cleaner in a can? I've used distilled vinegar on carbs and it worked great.
I use common inexpensive household rubbing alcohol, with a water sprayer attachment on the plastic bottle.
