High speed wobble... :O
- ELCouz
06 Aug 2011 18:51 - 06 Aug 2011 18:57
Dear KZ Riders
For the first time on a track test (for fun) when I've reached over 115 mph until top speed 130 mph. The steering started to wobble but not a tank slapper, slowly waving.
At 60 mph, i noticed its easy to get it wobble just by pushing a gently each side (less than 1/4 inch) alternately ... could this because bad steering bearing? I don't feel any play at all in the steering that's why I'm asking?
EDIT: feeling like it's too sensitive (steering) over 60 mph... or maybe it's just me :laugh:
regards,
laurent
regards,
laurent
1982 KZ810-R1 GPZ with hindle 4-into-1 pipe
Last edit: 06 Aug 2011 18:57 by ELCouz.
Re: High speed wobble... :O
06 Aug 2011 19:18
I'd check things out in this order:
1. Tires (they can look good, be mounted & balanced right, and have correct pressure and still cause high speed wobble - this happened to me).
2. Swingarm pivot bushing/bearing play (lift rear wheel off ground; disconnect shocks; see if you can twist swingarm at all - you should not be able to)
3. Steering stem bearings (lift front wheel off ground and see if there is any fore and aft play - too lose; also see if handlebars can flop to either side with zero resistance - too lose; there should be only very slight resistance but they should not be sloppy
4. Rear shocks
4. Rear shocks
06 Aug 2011 19:25 - 06 Aug 2011 19:26
Double posted - thanks Comcast.
Last edit: 06 Aug 2011 19:26 by 650ed.
- MFolks
06 Aug 2011 19:26
I copied this from a post from Jeff Saunders(owner of Z1 enterprises)
Motorcycle Wobble Causes
There's a LONG list of potential area that can cause this.
These are not in any particular order
Wheel bearings
Steering bearings - repack grease, check tightness
Swing arm bushings/sleeves/bearings - replace is worn, repack grease
Fork springs aging - check spring length
Unequal fork oil - if seals leak, then your damping can be ineffective
Rear shocks aging, damper leaks - if you have oil leaking from the seals, the damping is toast.
Worn Tires/Mismatched tires/tire pressures/wrong size tires
Wheel alignment - don't trust the chain adjusters - I visually align the wheels.
Bent rims/broken spokes - get the wheels off the ground and spin them - check for runout / damage
Front disc warped - check for runout
Steering & swing arm bearings are very common problems, but so are tire issues (pressure/mismatch) and wheel alignment.
Wheel bearings
- ELCouz
06 Aug 2011 19:30
thanks guy, i will check these
btw, i think the steering bearing is taper on the KZ750-R1 1982 (GPZ) ... do i need special tools to change this?
thank you very much
regards,
laurent
thank you very much
regards,
laurent
- jonnybravo
- Banned
06 Aug 2011 23:24
I had wooble but reduced it by adding a fork brace from .. to fast from the past,,, they have a full range of fork braces
- ELCouz
06 Aug 2011 23:27 - 06 Aug 2011 23:27I had wooble but reduced it by adding a fork brace from .. to fast from the past,,, they have a full range of fork braces
Isn't the second purpose of the wheel guard to act as a fork brace ?
Thanks for the site but unfortunately they don't have a fork brace for my model KZ750-R1
regards,
laurent
Last edit: 06 Aug 2011 23:27 by ELCouz.
- ELCouz
06 Aug 2011 23:49 - 06 Aug 2011 23:50Thanks for the site but unfortunately they don't have a fork brace for my model KZ750-R1
Nevermind found them it was on another page
www.fastfromthepast.com/servlet/the-556/...asaki-KZ750GP/Detail
When money flows again, this and a new set of rear shock are a must!
New set of tires + maybe steering bearing and swingarm but i need to check like 650ed told me
regards,
laurent
Last edit: 06 Aug 2011 23:50 by ELCouz.
- Old Man Rock
07 Aug 2011 09:21
I had a similar experience in my newly build that as you thought was steering head... Turned out to be something entirely different...
1) Raise the front end so front tire can spin freely.
2) Remove front fender for optimum view over top of tire/rotor.
3) While standing directly above tire/rotor, spin and see if either is warped....
Ah, sonsabitch there it was, rotors were rubbing on warped spots...
Just a thought...
Just a thought...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- steell
07 Aug 2011 11:58 - 07 Aug 2011 12:05
What you describe is more commonly called a weave, and on the GPZ750's the most common cause is overtightened steering head bearings (tapered bearings).
Interesting tidbit about a weave.
One of the cycle mags decided to do a top speed shootout to determine the fasted street bike. They fully expected Terry Kizer's (Mr Turbo) turbocharged ZX11 to win, but had to shut it down a little over 200 mph because they couldn't keep it in a 12 foot wide lane at that speed due to weave.
That bike had been on well over 100 (800 comes to mind, but not sure) dyno pulls as a development mule for the ZX11 Turbo kit, and the frame was tweaked. At least that was their determination as to the cause of the weave.
Boggles the mind :woohoo:
Last edit: 07 Aug 2011 12:05 by steell.
- mark1122
- Keep twisting it
07 Aug 2011 12:25 - 07 Aug 2011 12:31
i used to get into a tank slapper at over 100mph. pretty scary stuff. :woohoo: it turned out to be the front tire out of balance.
personally, i would put the fork brace on the very bottom of my wish list. it would only rely be a necessity ,for a track bike. as for aiding a wobble, i would rather get to the source of the wobble than try to tame it.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 07 Aug 2011 12:31 by mark1122.
- ELCouz
07 Aug 2011 20:01I had a similar experience in my newly build that as you thought was steering head... Turned out to be something entirely different...
Just a thought..
Good tip OMR thanks, i have a dial indicator i will check the run-out with that. My eyes, even if they are young play tricks on me sometimes
Thanks stell weaving is the correct term!
My are tires are due, they are Dunlop GT501. I think the date code say its made in 2001 :ohmy:
regards,
laurent
