Chain size 630 vs 530
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
Re: Chain size 630 vs 530
07 Aug 2011 21:01
#467567
steell wrote:
wireman wrote: lighter weight,stronger,cheaper more gear combinations...... B)
Looks like four good reasons to me.
Lighter by what? 6oz? Two 3/8" thick 8" dia. pieces of steel weigh the same where I live, 100" of chain are roughly the same weight, 10,000# tensile strength is 10,000# tensile strength, cheaper by what $10?, and a stock rear and +/- 1 on the front seems to work for a lot of people. As far as Otto goes, longer life?, fewer adjustments?, better mileage? All things being equal I fail to see how one would outperform the other in these areas.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
  • otakar
  • otakar's Avatar
07 Aug 2011 21:18 - 07 Aug 2011 21:27
#467570
The side plates of the chain are much thinner on the modern chains plus the rollers are also a bit smaller. I know for a fact that with everything being even on two bikes the quarter mile time difference is substantial. My buddy drag races a 83 GPz1100 (1500) turbo, and he dropped a whole third second when he went to the 530. you must realize that a couple of oz when spinning turn into pounds of centrifugal mass. Chain mass is a funny thing when it gets to spinning fast. I am giving you results right off of my GPz1150 I ran both on the bike and those are the results. The less HP out of the engine the greater the result difference will be. As I said multiple times before; I was a skeptic also before I switched. It took a couple of pros to convince me. I have no profit in this so do what ever you want. Mount a #60 industrial chain for what I care. It will mount right on your existing setup. I did that years ago when I did not know much. I thought that stronger is better. But it added 1# to the chain mass and took 15mi off of my top end on my Z1R, and added a whole second to the 1/4 mike.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 07 Aug 2011 21:27 by otakar.
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
07 Aug 2011 22:27
#467584
"Plus", you have more teeth in contact with the chain. Roy
  • Patton's Avatar Topic Author
07 Aug 2011 23:23 - 07 Aug 2011 23:25
#467599
Some interesting tidbits from the web:
www.ekchain.com/drag.htm
Drag Racing Chain Applications By Horsepower
530DRZ2 -- up to 500hp
more than 500hp -- 630SHB
www.3guyz.com/index.php?option=com_conte...7:examples&Itemid=94
Generally, if you compare a 530 chain to an equivalent rated 630 chain, you will find that the heavier pins and rollers afforded by the longer pitch will result in a stronger chain construction, and higher tensile strength. In a fixed length of chain, the 630 chain will have fewer pitches, many times resulting in less "set" or "stretch" as the chain wears. The sprockets for a 630 pitch have a matching 3/4" pitch, making the teeth larger, deeper, and stronger at the base of the tooth.
unitedparts.us/rk-streetbike-chains.aspx
532GSV XW-ring Rated up to 1300cc
Applications:
Rated up to 1300cc street applications, this streetbike chain has a maximum tensile strength of 9,200 foot pounds and a wearlife index of 1,000.
630GSV XW-ring Rated up to 1400cc
Applications:
Perfect for police bikes and bikes to up to 1400cc. 630GSV has a maximum tensile strength of 11,300 foot pounds and a wearlife index of 1,000.
Which oil's the best?
Which tires?
Good Fortune! :)
Last edit: 07 Aug 2011 23:25 by Patton.
  • wireman
  • wireman's Avatar
08 Aug 2011 01:33 - 08 Aug 2011 01:57
#467639
the 530 on the back of my 1327 was closer to 12,000psi,that little bit of weight all ads up when youre spinning that back wheel at 100 plus mph. :laugh:i stand corrected,my 530zzz chain was only rated at 11,000 psi! :woohoo:
Last edit: 08 Aug 2011 01:57 by wireman.
  • Old Man Rock
  • Old Man Rock's Avatar
08 Aug 2011 08:42 - 08 Aug 2011 08:44
#467663
Ah for KZ Christs sake...
For all the manufacturers, low end chains (cheaper) won't have the same tensile strengths/specifications as the higher end series they offer... Ek for example, compare their cheapest 530 pitch chains to their ZZZ series, ya they can get expensive over the costs of a 630 chain but definitely strong enough for a KZ...
How many gear change possibilities any of us really going to do ya can't accomplish with a 630... Hmmm... :S
As for colors, WTF ya want pink?... :blink: Can you get a matching pink rear sprocket now days.... :sick:
All in all, if it works for ya and you're not adjusting your chain twice a week :whistle: , awesome use it....
As for weight, again take a good dump... Same effect...
:laugh: :laugh: :laugh: You guys kill me :laugh: :laugh: :laugh:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 08 Aug 2011 08:44 by Old Man Rock.
  • wireman
  • wireman's Avatar
08 Aug 2011 09:44
#467671
hey dont you have some carb jets to buff out om-grump? :woohoo:
08 Aug 2011 10:14 - 08 Aug 2011 10:15
#467676
Old Man Rock wrote: "..As for colors, WTF ya want pink?... :blink: Can you get a matching pink rear sprocket now days..."
Why stop at the sprocket? :laugh:
Attachment Colortires.jpg not found
Last edit: 08 Aug 2011 10:15 by 650ed.
  • otakar
  • otakar's Avatar
08 Aug 2011 10:28
#467678
My chain has to match my socks and my underwear. ;) On some "sporting" rides that might be one color when I start out and at the end winds up being brown. :blush: :whistle: :evil:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • wireman
  • wireman's Avatar
08 Aug 2011 17:23
#467754
otakar wrote: My chain has to match my socks and my underwear. ;) On some "sporting" rides that might be one color when I start out and at the end winds up being brown. :blush: :whistle: :evil:
:woohoo:
  • Old Man Rock
08 Aug 2011 23:33
#467882
Here ya go Plumi...
Dupli-Color Pink Diapies for ya..... :whistle: :evil:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • wireman
  • wireman's Avatar
08 Aug 2011 23:39
#467884
Thats the last time i ever go to a slumber party with you/craig! :woohoo:
