What brake do I have?
- KZCM
06 Aug 2011 11:08
1980 KZ1000E2 shaft and I have the rear disc torn down. I ordered new piston seals and dust boots from Z1 and thought I'd received the wrong dust boots as they were too small. So, I ordered some from Redline and they were the same size. At this point I really doubt both of these folks would send the wrong part so the next conclusion is that my bike has something other than what's supposed to be on it. The picture is what came off the bike and what I received from both Z1 and Redline. The larger boot on the right is what came off the brake. Any ideas?
1977 KZ1000 - Wish I still had it
1980 KZ1000E2 - My project
Re: What brake do I have?
06 Aug 2011 11:43KZCM wrote: 1980 KZ1000E2 shaft and I have the rear disc torn down. I ordered new piston seals and dust boots from Z1 and thought I'd received the wrong dust boots as they were too small. So, I ordered some from Redline and they were the same size. At this point I really doubt both of these folks would send the wrong part so the next conclusion is that my bike has something other than what's supposed to be on it. The picture is what came off the bike and what I received from both Z1 and Redline. The larger boot on the right is what came off the brake. Any ideas?
Would measure size of the caliper piston which might be 42mm instead of 38mm.
Z1E likely also carries the larger size.
06 Aug 2011 11:52 - 06 Aug 2011 11:52Patton wrote:KZCM wrote: 1980 KZ1000E2 shaft and I have the rear disc torn down. I ordered new piston seals and dust boots from Z1 and thought I'd received the wrong dust boots as they were too small. So, I ordered some from Redline and they were the same size. At this point I really doubt both of these folks would send the wrong part so the next conclusion is that my bike has something other than what's supposed to be on it. The picture is what came off the bike and what I received from both Z1 and Redline. The larger boot on the right is what came off the brake. Any ideas?
You're right, it needs to be measured prior to ordering (see Z1E note):
www.z1enterprises.com/Frontrear-caliper-...1000-KZ1300-263.aspx
Last edit: 06 Aug 2011 11:52 by 650ed.
- KZ_Rage
- Kentucky Bourbon Barrel Ale
06 Aug 2011 16:07
Oddly though the piston and seal was changed the dust seal was never noted as different. That doesn't mean though that it isn't, measure the OD of the piston to be sure.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
1984 KZ550F2 SOLD!
- KZCM
06 Aug 2011 17:35 - 06 Aug 2011 17:37
Looks like I reversed myself on the picture description since the larger dust boot is on the left - not right. Anyway. . . .The piston is a 42mm. Both Z1E and Redline sent the correct size piston seal so that's no problem. But the dust seal is still too small.
KZ_Rage, are you saying when they went to a larger piston, everyone forgot about the need to make a larger dust boot?
Last edit: 06 Aug 2011 17:37 by KZCM.
- KZ_Rage
06 Aug 2011 17:52
No I'm sure the dust boot changed as well, it is just that there is no mention of a new part number for the dust boot. I can't even tell if the change in piston and seal was for the 38mm vs 42mm versions. Kaw is not the best for this info unless you happened to work for them back then maybe.
If you have the 42mm piston and your dust seal is for the 38mm then contact Jeff at Z1 about the kit coming in with the wrong dust seal in it.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
1984 KZ550F2 SOLD!
- KZCM
06 Aug 2011 18:03
I sent them an email last week but haven't received a response yet. My job has me traveling 400 miles away with very limited access to internet so follow up is sometimes difficult. But, I'll follow up with a phone call this week. I sure would like to get this brake reassembled sometime soon! Ironically, the parts from Redline were short one of the piston seals. I guess I'll just concentrate on something else for awhile. There's still plenty of parts left to refurbish!
