Braided Brake Lines. Thoughts, comments wanted.
  • Tested
  • Tested's Avatar Topic Author
04 Aug 2011 00:54
#466732
I am looking at replacing my front brake lines. The one from the MC to the 3 way joint is cracked in a couple places and I am having intermittent front brake usage.
Has anyone used them? Any thoughts? Are they better than the standard issue? Tougher, more durable, make you stop better (i kid).
I don't like that they all seem to come in chrome.
If I have drag bars what length should I get? Just measure the length with a tube and go from there?
2008 KLR 650
1977 KZ 750
_____ Have had _____
1981 KZ 440
1970's CR 125
1982 KLX 175
  • MFolks
  • MFolks's Avatar
Re: Braided Brake Lines. Thoughts, comments wanted.
04 Aug 2011 01:51
#466738
Brake Lines
www.galferusa.com/html/ss_line_kits.html
inlinetube.com/
www.spieglerusa.com/cfm/brakelines.cfm
www.helusa.com (I'm using them, they come with several colors)
www.russellperformance.com/metric_two-line.shtml
www.goodridge.co.uk/motorcycle-brake-lines/kawasaki.htm
Most brake line builders will custom make lines for you, just tell them the dimensions. Unprotected brake lines will act like a slow speed file,cutting through paint,electrical wiring,and other brake lines.
To protect my bikes systems, I went to Radio Shack and bought a package of black spiral wrap tubing. It's 1/4" in diameter but will expand up to maybe 3/8".
  • Old Man Rock
  • Old Man Rock's Avatar
04 Aug 2011 08:40
#466761
Custom lengths, color and fittings...
And yes they'll actually make you stop better where all energy is applied to the caliper pistons versus the line expanding. ;)
Attachment SPeiglerBrakeLines.JPG not found
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • trianglelaguna
  • trianglelaguna's Avatar
04 Aug 2011 08:58
#466766
a tip i am keeping as i get ready to try a brand also...is that a fabric tape and a note pad will get me close enough to what i need if done with some thought...when i figure who i use...i am leaning towards bringing the bike and the fabric tape to the decades long, parts man, at the kawi shop,it would be my first real help i have paid for there... and using his products...he will order and work with any problems until i have the right goodies and am stocked for repairs ect...a true fit kit.....i install he just walks along and helps with backing any glitches
he mentioned the brand and it is the one of the great ones always popping up in these steel lines suggestion threads...but the fittings and previous order record and his knowing the reps...i am sold almost right?
was close to 200 tax and riding away i think
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
04 Aug 2011 10:14 - 04 Aug 2011 10:15
#466776
Tested wrote: .... Just measure the length with a tube and go from there?
You should also determine if the brake hose connectors need to be straight or angled. Connectors are available in a variety of configurations. I've seen installations where angled connectors were needed but straight connectors or wrong angle connectors were used and the hoses ended up being very poorly routed - not cool. Here's an example of connectors:
Attachment BrakeJoint.jpg not found
Last edit: 04 Aug 2011 10:15 by 650ed.
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
04 Aug 2011 17:13
#466837
I'm running Goodridge braided lines for all four of my brake lines. They come with a plastic like coating on them to protect the painted finishes they touch. I also run drag bars and I'm sure the line from the mc to the splitter is 9" and from there to the calipers are 15". If I recall correctly they offer them in black braid as well. Also, Ed is right on the money about the fittings, if you don't get the right ones for each connection, it will look like 400# ass.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
  • testarossa
  • testarossa's Avatar
04 Aug 2011 18:05
#466843
+1 on the Goodridge lines. I have them on my bike, and I'm satisfied. One nice thing about the Goodridge lines is that the end fittings are replaceable. If you decide on the wrong angle, just swap it out and re-bleed. Not possible with the custom made lines. Plus they are sold in 1" increments, so you can get real close on the OAL.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • Tested
04 Aug 2011 18:43
#466848
Awesome!! Thanks guys I will look into it and make a plan for where my bike money is going next payday.
One of these days this bike will be bad ass. It just seems like one problem after another keeps presenting itself.
Now my headlight only wants to work intermitently. I don't mind though. I am learning a ton about motorcycles and am really getting into it. My wife calls my bike the other woman.
Iv'e ridden bikes since I was little but never really did anything to them. Just rode them until they broke then got rid of them. This one I'm gonna keep around for awhile.
2008 KLR 650
1977 KZ 750
1981 KZ 440
1970's CR 125
1982 KLX 175
  • MFolks
  • MFolks's Avatar
04 Aug 2011 18:51
#466851
I'd open up the headlight housing and check the three prong socket for corrosion and loose wires.
Color Codes On Most Kawasaki’s (written for 1980’s bikes)
HEADLIGHT
RED with BLACK stripe, High Beam.
RED with YELLOW stripe, Low Beam.
BLACK with YELLOW stripe, the ground circuit.
BRAKE/TAIL LIGHT Can be an # 1157 dual filament bulb
RED, Running or Tail Light.
BLUE,(sometimes with a Red stripe) Brake Light Circuit.
LEFT FRONT TURN SIGNAL Can be an #1157 dual filament bulb
GREEN, Left front turn signal circuit.
BLUE, Left front running light circuit.
RIGHT FRONT TURN SIGNAL Can be an # 1157 dual filament bulb
GREY, Right front turn signal circuit.
BLUE, Right front running light circuit.
LEFT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREEN, Left rear turn signal circuit.
RIGHT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREY, Right rear turn signal circuit.
Also check the high/low beam switch in the left handlebar switch pod for corrosion/bad solder joint.
  • martin_csr
  • martin_csr's Avatar
Re: .
04 Aug 2011 19:38 - 22 Jan 2013 03:15
#466864
Last edit: 22 Jan 2013 03:15 by martin_csr.
  • andy9802gt
04 Aug 2011 22:07
#466891
Martin is right, I'm running a 9" upper line plus about 3" of fitting length. I should have clarified that in my post, sorry. Same goes for the lengths of the lower line, that is without the fittings added in.
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
  • KZ_Rage
  • KZ_Rage's Avatar
  • Kentucky Bourbon Barrel Ale
06 Aug 2011 16:18
#467260
MFolks wrote: Brake Lines
+1 on the Hel's but mine were the encased type so no need for the spiral wrap.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
