MK2 fork tube; is this as far as I can go
  • MkII
  • MkII's Avatar Topic Author
03 Aug 2011 22:35
#466696
bottom view of fork tube, unlike the A1...no circlip to remove barrel and spring, spring seat, ect.
this looked like the inner 'sleeve' would come out and the 'shoulder' is the spring and spring seat you see, is locked in there.....this sob will not give me a hint of movement after flushing with solvent, clean as a whistle and liberal heat gun won't even do it.
Is this as far as you can break these down??? it can't be.
Anyone know who makes replacement fork tubes for MK2's??
1977A1 current project: 1075, Web cams, VM29's Cavanaugh massaged head, Z1 crank
1979A3A Parked in 1986 left in shed
Phx,Az
  • steell
  • steell's Avatar
Re: MK2 fork tube; is this as far as I can go
04 Aug 2011 00:51 - 04 Aug 2011 01:04
#466731
The 1000's are not my primary interest, so I guessed that MK2 referred to the 79 KZ1000A3 in your sig.
Here's the parts breakdown for the forks, but I haven't figured out what that piece is inside the fork.
Spring removed?
Damper removed?
Last edit: 04 Aug 2011 01:04 by steell.
  • Tested
  • Tested's Avatar
04 Aug 2011 00:57
#466733
@stell - Your avatar is very distracting.
Thanks.
Back to your regular scheduled program.
2008 KLR 650
1977 KZ 750
_____ Have had _____
1981 KZ 440
1970's CR 125
1982 KLX 175
  • steell
  • steell's Avatar
04 Aug 2011 01:10
#466734
Top diagram is A3 while bottom is A1, at least so far. Things get wacky when I link pics here from kawasaki.com.
I tried for a day or two to switch my avatar, then decided to add it to my sig.
Thanks to who ever got it to work.
Not near as intimidating as the cat though :P
  • SPARKY47
  • SPARKY47's Avatar
  • 1980 KZ500 B2
04 Aug 2011 19:13
#466853
Pussy can be a problem.
1980 KZ500 B2
