How to have handlebar on a gpz1100?
- jcote75
03 Aug 2011 01:40
HI,
Is there a swap that can be done in order to have handlebar instead of the clip on?
Triple from a kz1000P look to be wider. Are triple from a CSR would work?
Anyone done this?
Tks,
JOce
Anyone done this?
Tks,
JOce
- thug
Re: How to have handlebar on a gpz1100?
03 Aug 2011 06:03
You can always fit risers to the top triple by drilling it and installing them.Done this a good few times on all sorts of streetfighters and chops.
I also always had them welded to the triple as well as just using the bolt/bolts on the risers
KZ1100 A3 shaftie
- jcote75
04 Aug 2011 11:01
I was more looking for a triple swap.
Anyone know if a CSR1000 would work?
I allready have soem Kz1000j fork and triple tree but the ignition switch is the ate the same place....
- otakar
04 Aug 2011 11:13
You would have to swap everything on top. The headlight, ignition switch, instrument cluster, and so fort will not fit. I have used the CSR clamps and I had to custom build EVERYTHING on top.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
04 Aug 2011 11:16 - 04 Aug 2011 11:22
This is my custom built installation.
Attachment DSC01683.JPG not found
Attachment DSC01684.JPG not found
Attachment DSC01691.JPG not found
Attachment DSC01687_2011-08-04-2.JPG not found
Attachment DSC02155.JPG not found
Attachment DSC02236.JPG not found
Attachment DSC02237.JPG not found
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 04 Aug 2011 11:22 by otakar.
- jcote75
04 Aug 2011 11:27
Nice work!
Guess I'll pass for the csr parts....
I'll probably keep the clip on then...
