Chain came off while driving!!
  • Tested
  • Tested's Avatar Topic Author
02 Aug 2011 17:04 - 02 Aug 2011 17:05
#466406
So here I am cruising down the road when the bike decides it want's to rev out and barely move.
I pull over thinking that either the clutch or the transmission was fried. I dismount and get to look around. I see what looks like aluminum metal shaving all over the swingarm by the chain. I'm like freaking great. I just got the thing back on the road and it tore the tranny up. Then I look and see the sproket teeth. I'm like "WTF, the freaking chain came off like my Mongoose in middle school!" I hold it on and roll the bike backwards and it pops on.
Now for my question. Do I just need to tighten the chain up or is there more likely a more serious problem that I need to address?
ETA: 77' KZ 750.
2008 KLR 650
1977 KZ 750
_____ Have had _____
1981 KZ 440
1970's CR 125
1982 KLX 175
Last edit: 02 Aug 2011 17:05 by Tested.
  • testarossa
  • testarossa's Avatar
Re: Chain came off while driving!!
02 Aug 2011 17:18
#466408
Seems to me that you need to pull the cover over the countershaft sprocket and have a look. I'm assuming that the chain isn't broken, and just came off on it's own. Is this bike new to you? Any idea how long that chain has been on there? Got any pictures of the sprockets?
If the countershaft sprocket is still in place and properly torqued, and if the sprockets and chain are not worn, then I would have to guess that it was a tension issue that caused it to de-rail.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • TexasKZ
  • TexasKZ's Avatar
02 Aug 2011 17:43
#466410
And what did all those metal shavings used to be?
  • Tested
02 Aug 2011 18:19 - 02 Aug 2011 18:21
#466415
@ testarosa - Will do. I'm thinking that the rear sproket might need replacement. I have had the bike for a month or so. I imagine that the chain is most likely original. I just put a bunch of cash into the carbs, ingition, paint and such. Gonna have to wait on a chain and rear sproket.
@ texasKZ - I'm guessing that it is from the rim and prolly part of the front sproket and the case. Scared the tar outa me when I saw them. I got the chain back on and it drove fine the five miles back to work.
Nothing like leaving the State Taxman office after a visit on lunch to have your bike pull a stunt like this.
ETA: Which rear sproket should I put on it if I do replace it.
2008 KLR 650
1977 KZ 750
1981 KZ 440
1970's CR 125
1982 KLX 175
Last edit: 02 Aug 2011 18:21 by Tested.
  • trianglelaguna
  • trianglelaguna's Avatar
02 Aug 2011 19:39 - 02 Aug 2011 19:44
#466431
you know what...you be lucky.....
veby veby veby lucky........
chains circulating at high speed can do amazing things in a heartbeat...good you had no issues
that aside..take a peek in there and see...bet you can see some condition of the front sprocket ,peeking behind the area the chain goes into the cover,,, might be time for new chain and sprocket set.... but if the gear you have is fine and the (post a pic, i cant imagine the chain spinning and not eating more goodies) rear sprocket is in good shape....then lube and adjust and forget about
but damn gina...you be lucky....good for you
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Last edit: 02 Aug 2011 19:44 by trianglelaguna.
02 Aug 2011 21:34
#466459
Lucky is right! I can't believe you just put the chain back on the sprocket and rode it like that. Picture this: You're riding along minding your own business with a truck behind you. Your chain pops off the sprocket again, but oh oh, this time it wedges betwen the sprocket and swingarm and locks up the rear wheel. This makes a long black stripe on the street followed by a long brown stripe followed by a long red stripe. I'm not trying to preach doom & gloom, but you really should be taking this maintenance thing serious. Not doing so can literally kill you and we don't want to lose anybody. Please be careful. Ed
  • P21
  • P21's Avatar
02 Aug 2011 21:52
#466464
if i where you i would now change the name from TESTED to Lucky Azz
all i have to say is lady luck was on your side man and dont forget it
now check that front and rear sprockets good and KEEP an EYE on the chain slack
not a harper but you one lucky basterd
Kawasaki KZ 1000 Police (2002) P21
  • Tested
03 Aug 2011 11:09
#466567
I took care of it as soon as I got back last night. I didn't have access to tools where I was and not driving it wasn't really an option. There are some neighborhoods around here you don't wanna leave a motorcycle parked in.
There was a ton of slack in it. I adjusted it to where there is about 1-1.5" of travel in it.
Thanks for the concern guys. I know I was glad the damn thing didn't snap and wrap around my leg. I'll post a pic of the sprocket, chain and master link tonight.
2008 KLR 650
1977 KZ 750
1981 KZ 440
1970's CR 125
1982 KLX 175
03 Aug 2011 12:55
#466580
1" is ok. 1.5" is too much slack. Ed
  • Tested
Re: Updated with PICS -Chain came off while driving!!
04 Aug 2011 23:22
#466911
@ ED - Thanks, fixed it.
Here are some pictures of the sprocket and chain. What do you guys think? Should I replace the sprocket?
I know you can't really say on the chain without seeing the stretch on it. Notice in one of the pics. that there is a master link. According to the manual there should be. That tells me this is a replacement chain that is most likely not up to spec. Do you agree?
2008 KLR 650
1977 KZ 750
1981 KZ 440
1970's CR 125
1982 KLX 175
  • Motor Head
  • Motor Head's Avatar
04 Aug 2011 23:31
#466915
You need a new chain and both sprockets. Get a sealed chain, like an X-ring from Z1. They last a lot longer, and the initial cost is only slightly more. Replace it and get some good quality chain lube to keep it going for many miles.
The following user(s) said Thank You: Tested
  • testarossa
04 Aug 2011 23:36
#466921
That rear sprocket is toast IMO. Both sprockets and the chain really need to be replaced as a set. Trying to use any one worn part with any other new part will only wear the new parts out faster. Sucks to say it but it's the only right way to do it. I wouldn't trust a chain that has de-railed personally.
BTW that chain and sprocket has been replaced before. That rear sprocket is aluminum. I prefer steel sprockets for longevity.
2004 ZX-10R
Angola, IN
