rear shock adjustment
- jacksdad
- 1979 kz 750 OUCH, IT SPARKED
30 Jul 2011 18:30
anybody have an idea of how to adjust the rear shocks, manual says there are three positions and you need a hook spanner, I do not have a hook spanner, nor will I purchase a hook spanner in the near future (broke) just a curiosity, thanks in advance
1979 kz750 twin cyl.
- MFolks
Re: rear shock adjustment
30 Jul 2011 18:33
If you look at the rear shocks, there is a ring with ramps on it to adjust the spring pre load. The hooked spanner has a tooth or square section designed to engage this opening on the ring.
- jacksdad
30 Jul 2011 18:39
can it be sone without a hook spanner?
30 Jul 2011 18:48
You may be able to wrap a piece of thick leather (i.e. from an old belt) around the adjuster to protect it and turn it using Channellock pliers. Ed
- P21
30 Jul 2011 18:48
the (broke ) mans way
use plump pliers big azz pliers will work
and use a rag on shock as to not mark shocks.
Kawasaki KZ 1000 Police (2002) P21
- steell
30 Jul 2011 22:33
In the past I've always just grabbed the ring with by bare hand and turned it while pulling upward.
Don't know if I can still do that though
- redneckcarrow
31 Jul 2011 22:50
put it on the center stand and use big pair pliers
1980 kz 550 ltd stock
- jacksdad
05 Aug 2011 00:47
that was a whole lot easier to turn than I thought it would be. i like the ride better now that it is at it's lowest point, not as stiff
