Lower Steering Head Bearing????
  • badrhino
  • badrhino's Avatar Topic Author
28 Jul 2011 20:41 - 28 Jul 2011 20:45
#465572
I am having trouble getting my lower steering head bearing(race) all the way in. I am just flush with the bottom of the neck. Need to know what all ghetto tools people used to get it pushed in all the way, what you used, what size, etc......I was using a pvc joint to get it in that far but it is too wide to go any further. Any suggestions? I don't have any sockets that large either.:unsure:
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Last edit: 28 Jul 2011 20:45 by badrhino.
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
Re: Lower Steering Head Bearing????
28 Jul 2011 22:51
#465590
I always use a hammer and a punch. You don't have to beat on it just go around the perimeter in a uniform pattern. Roy
  • Motor Head
  • Motor Head's Avatar
28 Jul 2011 23:58
#465613
Brass or Bronze punch would be best. A steel can easily damage a bearing race.
29 Jul 2011 00:02
#465615
If you don't have a brass or bronze punch or drift you can use a piece of wooden dowel. Ed
  • badrhino
29 Jul 2011 00:13
#465619
Ok, thanks guys. I didn't know if I could do it that way or not. It crossed my mind a few times. lol
I might try the wooden dowel method first however.
Franken Z!
  • Motor Head
29 Jul 2011 00:22
#465625
For future, you might consider a set like this: www.harborfreight.com/10-piece-bearing-r...river-set-95853.html
I have 2 sets from Mac Tools I've had for many years. They don't fit every bearing, but they do most of them. Very handy.
  • badrhino
29 Jul 2011 12:17
#465697
I seen those in an ad and right now I believe they are only $19.95.
Franken Z!
  • badrhino
30 Jul 2011 02:10
#465804
I just bought a small piece of pvc pipe in same diameter and beat it right in.:lol:
Franken Z!
  • badrhino
01 Aug 2011 11:55 - 01 Aug 2011 11:58
#466160
So now that I have the races on it is time to put the bearings on and then put it together. How snug do you get the slotted washer(stem locknut) when tightening it up?
Franken Z!
Last edit: 01 Aug 2011 11:58 by badrhino.
