kz1000 fronend
  • oldskoolatheart
  • oldskoolatheart's Avatar Topic Author
kz1000 fronend
28 Jul 2011 15:36
#465541
I am just wandering if anyone can tell me if a kz1000 front end will fit on a kz650 frame. Thanks
1978 Kawasaki KZ650
Work hard, Play harder
  • steell
  • steell's Avatar
Re: kz1000 fronend
29 Jul 2011 01:13
#465635
Assuming we're talking 77-80, then yes it will.
But I have to ask why, it's an inch taller but everything else is pretty much the same.
Both are 36mm diameter and both use the same front axle diameter.
  • oldskoolatheart
Re: kz1000 fronend
29 Jul 2011 14:47
#465712
Ok...thanks. I was wanting to know because there was a shortened kz1000 frontend I was looking at buying on ebay. I just wasnt sure if it would fit on my kz650.
1978 Kawasaki KZ650
  • steell
  • steell's Avatar
Re: kz1000 fronend
29 Jul 2011 16:43
#465728
As long as it's a 1980 or earlier.
Stock KZ1000 front end is 1" longer than yours, can't think of any that are shorter at the moment.
Easy swap, bolts right in, just have to use 1000 brake rotors because the caliper sits higher on the fork on the 1000
