KZ1000 dual disc replacement master cylinder
- Kapahulu
20 Jul 2011 19:21 - 20 Jul 2011 19:21
I'm wondering what master cylinders off other bikes will be suitable for a KZ1000 running dual discs?
I've used those master cylinders off E-bay before sold by usa-motorcycles-inc. They look good for about a year and then the paint starts flaking, the fluid level glass (plastic?) gets foggy, etc.
Looking for something better, what are your suggestions?
I think it might be easier to use a later model master than fix up an old original KZ1000 master.
2strokeworld.com
2strokeworld.com
Last edit: 20 Jul 2011 19:21 by Kapahulu.
- Topper
Re: KZ1000 dual disc replacement master cylinder
20 Jul 2011 19:50
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
1979 KZ750 Twin
- Kapahulu
20 Jul 2011 20:14
OK. I already have dual discs though. Just looking for an good replacement master cylinder, wondering if a ZX6, ZX10, ZRX or other master would work well on a KZ1000.
2strokeworld.com
2strokeworld.com
Last edit: 15 Feb 2013 11:23 by martin_csr.
- Ktm181
- Man made it, so Man can fix it
24 Jul 2011 21:42martin_csr wrote: You should be able to use the Fr Br mc from just about any Japanese bike... including a Honda. hee.
The basic criteria: 7/8" bars, mount angle, dual disk (or single disk), mirror orifice. Some modern mcs don't have the orifice.
Plus you should be looking to run same BORE SIZE mastercylinder otherwise different braking is result. Steell has good info there IMO.
Kt
- steell
24 Jul 2011 22:38 - 24 Jul 2011 22:43
95-96 ZX1100E (GPz1100) has a master cylinder with mirror mount hole and that looks quite similar to the late seventies KZ750 and 1000. And the best is, this exact same master cylinder is used on a bunch of Kawasakis up to at least 2002, and rebuild kits are easy to find. And they're cheap on eBay.
And they work on low to medium bars.
What's not to like??
43015-1498
Used on the following models, up through 2006
Model (36):
ZG1000-A10 (Concours) (1995)
ZG1000-A11 (CANADA ONLY) (1996)
ZG1000-A12 (Concours) (1997)
ZG1000-A13 (Concours) (1998)
ZG1000-A14 (Concours) (1999)
ZG1000-A15 (Concours) (2000)
ZG1000-A16 (Concours) (2001)
ZG1000-A17 (Concours) (2002)
ZG1000-A18 (Concours) (2003)
ZG1000-A19 (Concours) (2004)
ZG1000-A20 (Concours) (2005)
ZG1000A6F (Concours) (2006)
ZG1000-A7 (Concours) (1992)
ZG1000-A8 (Concours) (1993)
ZG1000-A9 (Concours) (1994)
ZX1100-C3 (Ninja ZX-11) (1992)
ZX1100-C4 (Ninja ZX-11) (1993)
ZX1100-D1 (Ninja ZX-11) (1993)
ZX1100-D2 (Ninja ZX-11) (1994)
ZX1100-D3 (Ninja ZX-11) (1995)
ZX1100-D4 (Ninja ZX-11) (1996)
ZX1100-D5 (Ninja ZX-11) (1997)
ZX1100-D6 (Ninja ZX-11) (1998)
ZX1100-D7 (Ninja ZX-11) (1999)
ZX1100-D8 (Ninja ZX-11) (2000)
ZX1100-D9 (Ninja ZX-11) (2001)
ZX1100-E1 (GPZ 1100) (1995)
ZX1100-E2 (GPZ 1100) (1996)
ZX1100-E3 (GPZ 1100) (1997)
ZX1100-F1 (GPZ 1100 ABS) (1996)
ZX1200-C1 (ZZR1200) (2002)
ZX1200-C2 (ZZR1200) (2003)
ZX900-B1 (Ninja ZX-9R) (1994)
ZX900-B2 (Ninja ZX-9R) (1995)
ZX900-B3 (Ninja ZX-9R) (1996)
ZX900-B4 (Ninja ZX-9R) (1997)
43015-1498
Model (36):
Last edit: 24 Jul 2011 22:43 by steell.
- Kapahulu
27 Jul 2011 16:33
Steell that is very useful info, thanks a lot!
2strokeworld.com
2strokeworld.com
