Exchanging motor mount plates
- pete greek1
19 Jul 2011 17:15
Bought four motor mount plates from ebay and had them chromed with all the bolts, now I want to replace them with the ones on my bike. Can I do them two at a time? What would be the right sequence as far as top first or bottom first? Would I need to jack up my engine?
Any advice would be appreciated
- testarossa
Re: Exchanging motor mount plates
19 Jul 2011 17:41
I don't see why you couldn't do two at a time. I also don't feel like you should have to do them in any particular order. The remaining mounts will hold the motor up just fine. Personally I wouldn't worry about jacking up the engine if you were leaving most of the mounts in place and just replacing a set at a time. Unless you were unable to get the mount bolts through both sides. If you do decide to put a jack under the motor, do pad it with a board or something to prevent cracking the oil pan (It's aluminum.)
Nice looking LTD by the way.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- zed1015
19 Jul 2011 20:38
Do the bottom one first then the front one and then the two rears (motor won't move when done like that).
If you release both the bottom and front at the same time the motor has a tendency to lean slightly sometimes requiring the use of a rag wrapped tyre lever (or similar) between the frame and cases to line the holes back up.
