RearviewMirrors
  • BrysonWood
  • BrysonWood's Avatar Topic Author
RearviewMirrors
18 Jul 2011 03:45
#463448
not exactly sure if this is the right forum but here it goes. I own a 74 Kz400 and the mirrors a believe are not stock. but the mirrors attach to the mirror stand by a ball and socket joint. and the socket is becoming lose the mirrors will not stay in place and will just slide down with out bike vibrations i was curious if there is anything that i can adjust this by putting some kind of glue or if i could take it appart and tighten some sort of clamp? or do i just have to replace the mirrors?
1974 Kz400 Original
  • martin_csr
  • martin_csr's Avatar
Re: Mirrors Mirrorz Bitchin bitchin' hunt
18 Jul 2011 11:51 - 15 Feb 2013 10:45
#463488
I don't know if they can be fixed, but here's a mirror topic in case you decide to replace them.
KZR - Bitch'n Mirror Hunt Mirrors Mirrorz Bitchin bitchin' hunt
Last edit: 15 Feb 2013 10:45 by martin_csr.
Re: RearviewMirrors
18 Jul 2011 12:01 - 18 Jul 2011 12:07
#463491
BrysonWood wrote: not exactly sure if this is the right forum but here it goes. I own a 74 Kz400 and the mirrors a believe are not stock. but the mirrors attach to the mirror stand by a ball and socket joint. and the socket is becoming lose the mirrors will not stay in place and will just slide down with out bike vibrations i was curious if there is anything that i can adjust this by putting some kind of glue or if i could take it appart and tighten some sort of clamp? or do i just have to replace the mirrors?
Both stock 1974 KZ400 mirrors are reported by kawasaki.com as "active" meaning still available from the dealership.
Lots of good info on kawasaki.com, including parts diagrams, part numbers, models sharing same part, availability, etc.
Here's a link for help with navigating the site and finding information.
kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
Some of the stock mirrors, with a non-adjustable ball joint attachment between the plastic case and stalk, are prone to vibration and buzzy images at various road speeds and engine rpm.
Am unaware of any tightening method.
Good Fortune! :)
Last edit: 18 Jul 2011 12:07 by Patton.
  • martin_csr
Re: -
18 Jul 2011 12:27 - 18 Feb 2015 08:25
#463494
edit: eebbaayy link no longer works.
Last edit: 18 Feb 2015 08:25 by martin_csr.
Re: RearviewMirrors
18 Jul 2011 13:00
#463499
The left hand mirror part no. 56003-009 is shown by kawasaki.com as being shared on 92 models through 1990, and the right-hand mirror part no. 56002-020 on 98 models through 1991.
Yes, would be a good idea to phone the dealership, give them the specific parts numbers, and ask them to look up the parts for current availability, and the price (to compare with other sources).
Good Fortune! :)
Re: RearviewMirrors
18 Jul 2011 13:10
#463500
BrysonWood wrote: ...74 Kz400...mirrors attach to the mirror stand by a ball and socket joint. and the socket is becoming lose the mirrors will not stay in place and will just slide down with out bike vibrations...
Certainly not saying it can't happen, but don't recall ever seeing a stock mirror so loose that it just stays in flopped down position even while the bike is parked.
Good Fortune! :)
  • BrysonWood
Re: RearviewMirrors
18 Jul 2011 13:38
#463504
i dont think they are stock mirrors. . . but it sounds like i may have toe replace them with stock if i can find them
1974 Kz400 Original
  • martin_csr
Re: -
18 Jul 2011 13:59 - 15 Feb 2013 10:58
#463507
Last edit: 15 Feb 2013 10:58 by martin_csr.
