Centerstand Ballet . . .#%*&@
  • KaZooCruiser
  • KaZooCruiser's Avatar Topic Author
14 Jul 2011 11:01
#462803
Hi all, have not been here for some time.
But I M back with a problem.
I need help getting my KZ650 with a fairing on the centerstand.
Maybe it's me.
I try to roll it back and I can't get it up.
Try to push down, while lifting up.
Doesn't work.
It's really aggravating when the bike high sides.
I need to oil the chain.
  • otakar
  • otakar's Avatar
Re: Centerstand Ballet . . .#%*&@
14 Jul 2011 12:16 - 14 Jul 2011 12:18
#462811
Somewhere on this web sight there is a video or a series of pictures of a diminutive young lady puting a rather large bike on a center stand :blush:. It is actually quite simple. Once you have the center stand on the ground, with your right foot put ALL of your mass (lift your left foot off the ground)on the center stand lever while at the same time lifting on the handle bar and the grab rail. Do not attempt to LIFT the bike onto it. You will never be able to do so. You must use your body as a hydraulic piston between the stand lever and the two upper grab points not between the ground and the grab points.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 14 Jul 2011 12:18 by otakar.
  • riverroad
  • riverroad's Avatar
  • 1980 1000LTD B4
14 Jul 2011 12:20 - 14 Jul 2011 12:21
#462812
Try driving the back wheel up onto a piece of 2X4. Then as you rock back and pull with it, squeeze the front brake handle to hold position, then rock back again... repeat as necessary.
That's how I do mine. I don't have a fairing, but my center stand is off of a police bike, and I think it's longer than the one thats supposed to be on there.
I don't have a grab rail on mine.
Last edit: 14 Jul 2011 12:21 by riverroad.
  • TexasKZ
  • TexasKZ's Avatar
14 Jul 2011 12:26
#462813
:pinch:
Yikes ! Can't imagine how that happens.
Anyway, if that is a Vetter fairing (weighs about the same as a small Toyota) installed on a bike with old, saggy springs at both ends, then you may need a helper. If for any reason the suspension has been lowered, then it may be impossible. Anything that makes the bike sit lower than when it was new will put the center stand at an awkward angle, making deployment difficult.
  • TexasKZ
  • TexasKZ's Avatar
14 Jul 2011 12:29
#462814
otakar wrote: Somewhere on this web sight there is a video or a series of pictures of a diminutive young lady puting a rather large bike on a center stand :blush:. It is actually quite simple. Once you have the center stand on the ground, with your right foot put ALL of your mass (lift your left foot off the ground)on the center stand lever while at the same time lifting on the handle bar and the grab rail. Do not attempt to LIFT the bike onto it. You will never be able to do so. You must use your body as a hydraulic piston between the stand lever and the two upper grab points not between the ground and the grab points.
Leverage is the key for sure. There are also online videos of a small woman who goes by Skert picking up a Goldwing that's on its side.
  • TexasKZ
  • TexasKZ's Avatar
14 Jul 2011 12:54
#462821
Here's a center stand video
14 Jul 2011 14:50
#462834
riverroad wrote: Try driving the back wheel up onto a piece of 2X4....
+1
Click > www.kzrider.com/forum/21-tools/317801-ea...ift-onto-centerstand
Good Fortune! :)
14 Jul 2011 15:04
#462837
+1
Good Fortune! :)
Will that work with this bike? :evil: :woohoo:
Attachment long_2011-07-14.jpg not found
  • bountyhunter
  • bountyhunter's Avatar
14 Jul 2011 15:34
#462841
I have to get some rearward momentum going and then slam the stand down and stand on the lever. I agree an assistant would be helpful to keep from letting it get away from you.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
14 Jul 2011 15:35
#462842
^^^ If there was anything more useless....
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • riverroad
  • 1980 1000LTD B4
14 Jul 2011 16:21
#462847
Kidkawie wrote: ^^^ If there was anything more useless....
I can think of only one thing:
14 Jul 2011 17:26
#462857
Man, that nitwit must stand on the seat to reach the throttle. :laugh:
