KZ 750 swing arm swap
- kzcafe750_24
13 Jul 2011 22:02
Hey guys,
Just wondering if anybody has any info on this swingarm swap. kz750 4 cylinder using a 91 zr550 swing arm. If so this is the info I'm looking for:
- What rim rim will bolt right up? (GSXR,ZZR,CBR, etc) Don't want to use a zr550 rim, just because I don't like the style of them.Not looking for the widest either, stock rim and tire size will work just fine.
- What modding is involved?
- Any other ideas or info on this swap, would be great thanks.
Thanks Much,
Thanks Much,
1981 Kz 750-4 LTD - Wiseco 810 Big Bore,Ported cylinder head, GPZ 750 Cams,Dyna Ignition(DynaS,Green Coils,DRL400 2stage Revlimiter), RC 4 into 1 fitted with Yoshi muffler, ZR550 Swing arm, ZR550 Rear Rim, ZX750turbo front end SuperFlo Dyno Tuned- 68WHP&43WTq(ftlbs)
1986 Honda Rebel 250 (Stock)
1985...
1985...
- rabies
- holla
Re: KZ 750 swing arm swap
14 Nov 2012 13:07
id like to know too. i know this is old. anyone know the pivot width of the kz750 swing arm?
same as kz450-550-650-900-1000?
"boy its hot out.....oh..my bike is on fire"
- ramtough_63
14 Nov 2012 13:11
i have an 83 factory mono setup on an 87 if anyone needs measurements
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- rabies
- holla
14 Nov 2012 13:19
i found this but it doesnt give any measurements
"200-350: interchangeable
400-550: interchangeable
650:750: interchangeable although the twin model is a bastard when it comes to this the coils and starter clutch are all different.
900-1000: interchangeable"
14 Nov 2012 13:19
kz 1000 9 1/4" inside dimension of frame at pivot.
kz 700 9" inside dimension of frame at pivot.
thats all i know.
thats all i know.
- OneShoe50
- 10-4? 10-4!
17 Nov 2012 20:10 - 17 Nov 2012 20:10
I put a 81` KZ750E swingarm on my 77` KZ1000A, had to add two .100" spacers on each side to make up the difference in width, and square the swingarm in the chassis. Only needed a .020" shim on the countershaft sprocket to align with rear sprocket..
Why you ask, it is 1.5" shorter, makes the steering feel muck quicker, and I wanted to have the factory mag wheel rear and keep the 18" instead of the 16" LTD wheel. Plus the weight savings between the total package, about three pounds lighter.
FWIW, hope this helps.
77 KZ1000A1 - Under going a psuedo ELR overhaul
79 KE175 (gone)
81 KZ550A2 (gone)
81 KZ750E (gone)
Sure it looks OK now, but wait until I really make it pretty, with some chrome and paint and some new tires and grips and the wiring. Don't forget the gearing, and the LED's and, and, and....
79 KE175 (gone)
81 KZ550A2 (gone)
81 KZ750E (gone)
Last edit: 17 Nov 2012 20:10 by OneShoe50.
