1980 kz1000e2 shaft rear master cylinder
  • Kjack90
  • Kjack90's Avatar Topic Author
12 Jul 2011 00:25 - 12 Jul 2011 00:41
#462374
Well. I just saved a kz1000 that was on its way to be scraped. i know the carbs need cleaned and the front fork needs rebuilt from it sitting for 5 years with out moving or being ran.
but I am having trouble location the parts to rebuild the rear brake master cylinder. when i got it the cylinder was stuck. i got it unstuck cleaned it out and now it seeps oil from the seal and dust boot.
My question is would this
cgi.ebay.com/ebaymotors/KZ550-KZ750-KZ10...fPartsQ5fAccessories
fit for rebuilding the cylinder or what parts do i need to fix this problem.
1980 kz1000e2 shaft returned to factory airbox, with delkevic 4-1.
1982 xj650 bobber
2005 Suzuki Bandit gsf1200s
Last edit: 12 Jul 2011 00:41 by Kjack90.
  • KZ_Rage
  • KZ_Rage's Avatar
  • Kentucky Bourbon Barrel Ale
Re: 1980 kz1000e2 shaft rear master cylinder
12 Jul 2011 00:56 - 12 Jul 2011 01:01
#462385
Even the brake master changed on the shafty's from 79 to 80, they still had the same primary seal though, you can get any aftermarket kit for the following;
Part # = 43020-1015
Part Description = REAR BRAKE PISTON ASSEMBLY
KZ1000-C4A 81 POLICE 1000 POLICE
KZ1000-A4 80 KZ1000 MKII STREET
KZ1000-B4 80 KZ1000 LTD LTD STREET
KZ1000-C3 80 POLICE 1000 POLICE
KZ1000-D3 80 Z1-R STREET
KZ1000-E2 80 KZ1000 SHAFT STREET
KZ1000-G1 80 Z1 CLASSIC STREET
The seal and piston assembly aren't available from the dealer.
EDIT corrected info for E2, sorry
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
Last edit: 12 Jul 2011 01:01 by KZ_Rage.
  • KZ_Rage
  • KZ_Rage's Avatar
12 Jul 2011 00:57 - 12 Jul 2011 00:57
#462386
exploded
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
Last edit: 12 Jul 2011 00:57 by KZ_Rage.
  • Kjack90
14 Jul 2011 00:18
#462751
thank you. now to try to find the part. not having any luck so far. i tried cleaning the old one up to see if it may be savable.
1982 xj650 bobber
  • MFolks
  • MFolks's Avatar
14 Jul 2011 00:36
#462756
  • Chaotic Reason
  • Chaotic Reason's Avatar
18 Jul 2011 00:58
#463439
This guy does used parts: www.oldkawman.com/
Michael
1980 KZ1000 shaft drive
  • Kjack90
19 Jul 2011 17:54
#463803
well. I honed the master cylinder out and it seems to be holding for now. it still has a very very small leak that may have to stay. but I'm
m letting it sit for a bit before i do any more major work on it. now i have to rebuild all 4 carbs, install new tires, and get possible get a mac 4into 1 exhaust for it.
1982 xj650 bobber
  • Kjack90
27 Jul 2011 22:59
#465419
Well, looks like I'll be searching for new internals or a body for it. i cleaned it out and it still leaks. went from upper line to lower line in under 2 hrs. Once it hits lower line it appears to stop leaking though. .
The inside cylinder has some minor pitting which could be the cause or the rubber seals are worn down, But since it appears no one makes a rebuild for my bike.
i was wondering if any one knew if a 1981+ would be able to be fitted if i transferred over the linkage. or if any one has a working non leaking unit.
1982 xj650 bobber
