Yes, you CAN resurface bike rotors, Dorothy......
  • catseye
  • catseye's Avatar Topic Author
08 Jul 2011 12:41
#461706
Had these rotors w/ 10k miles and plenty of depth on them, but rusted and looked like an old LP:
went many places that said it couldn't be done, but I found a local machine shop who resurfaced them, for $22 each!
Now I have this:
I am :)
1982 KZ750LTD
1976 BMW R90/6
1982 Honda CBX
  • P21
  • P21's Avatar
Re: Yes, you CAN resurface bike rotors, Dorothy......
08 Jul 2011 12:50
#461707
they look nice but why would you lay them on concrete just to take picture
Kawasaki KZ 1000 Police (2002) P21
  • testarossa
  • testarossa's Avatar
08 Jul 2011 12:51
#461708
Looks good. Any idea what process that they used? Blanchard ground, perhaps?
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • DoubleDub
  • DoubleDub's Avatar
08 Jul 2011 14:53
#461719
More info please - mine have some nice grooves in them from the 47k+ (I'm certain they are the original). Were the wear measurements in the manual? I haven't found them yet (although I haven't searched hard).
  • badrhino
  • badrhino's Avatar
08 Jul 2011 14:56
#461720
That's to scuff them up a bit, make'm bite! lol
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
  • dutchz
  • dutchz's Avatar
08 Jul 2011 15:25
#461722
Looks nice! Blanchard ground would be my guess. I had that done on mine but not as cheaply I paid about $100 for both. This process is only possible if the rotor can be removed from the carrier if anyone wonders, like on these later model rotors.
Dub it is probably in the manual but the minimum thickness should be stamped on the disc as well.
1974 Kawasaki Z1
Stock front hub and rear axle.
  • catseye
08 Jul 2011 18:16 - 08 Jul 2011 18:20
#461741
correct. Minimum thickness (4.5mm f/6mm r) is stamped right on the rotor. I have .8mm+ to spare.
oh, and don't worry, I was careful not to scratch them on the concrete.....;)
1982 KZ750LTD
1976 BMW R90/6
1982 Honda CBX
Last edit: 08 Jul 2011 18:20 by catseye.
