hole in gas tank??
- gcarson64
hole in gas tank??
04 Jul 2011 00:46
hello i have recently noticed that the p/o drilled a hole in the gas tank (what ever reason) and then patched it with putty of some sort and it has begun leaking. now my question is what is the best way to fix the tank the hole is on the frame rail whatever you call it so it doesnt have to be pretty just hold gas for longer than the putty (less than a year)
1980 kz550 38,500 miles basket case ( soon to be a BOBBER )
1983 kz550 9,600 miles
1988 jeep grand wagoneer 144,500 miles 4 mpg
Re: hole in gas tank??
04 Jul 2011 00:54
The most permanent repair would be to braze it. You MUST empty and purge the inside of the tank very well before doing so to ensure no gas fumes are in there or KABOOM. A shop that does automotive repair should be able to do this. Ed
