Tubetype tire on tubeless rim
- Brown_Muscle
03 Jul 2011 19:33 - 03 Jul 2011 19:35
Okay...so I have a tubetype tire on a tubeless rim, need advice here, can i simply use a tube with it and call it a day or do i need a new tire? Or am i lucky and can run it as is?? Thanks guys!
PS, i know its in the wrong section...my bad, sent a message to a mod to please move.
1979 KZ1000ST
Last edit: 03 Jul 2011 19:35 by Brown_Muscle.
- Nebr_Rex
Re: Tubetype tire on tubeless rim
03 Jul 2011 19:42
Does it hold air without the tube?
Running a tube will not hurt a thing.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Brown_Muscle
03 Jul 2011 21:14
Yes it holds air nicely, i wasn't sure how dangerous it was. I'm kind of frightened as i've had the bike up to 70mph and gone 200 miles on it with this tire, being unaware this whole time it was a tube type
1979 KZ1000ST
- mtbspeedfreak
03 Jul 2011 21:16
Well, you're certainly not going to hurt anything by putting a tube in. I play it safe with tires.
2000 ZRX 1100
1976 KZ 900- Daily Driver
- ELCouz
03 Jul 2011 21:26 - 03 Jul 2011 21:27
Remember you are always two wheels away from hospital
Tire problem on a car pfff no deal....but on a motorcycle it could be deadly or scratchy !:ohmy:
1982 KZ810-R1 GPZ with hindle 4-into-1 pipe
Last edit: 03 Jul 2011 21:27 by ELCouz.
- racer54
03 Jul 2011 21:29
If you are having any doubts or concerns...put a tube in it!!! Nothing beats peace of mind...especially on a motorcycle. Listen to you gut and do what makes you feel safe, at peace and confident in the bike.
- Brown_Muscle
03 Jul 2011 21:39 - 03 Jul 2011 21:40
www.motorcycle-superstore.com/1/28/396/6...aspx?WT.ac=SLIsearch
That is the tire i have, 100/90/19. It holds air fine, i was worried about the safety. scarily enough i've ridden 200 miles on it and speed up to 75mph :blush: :pinch:
So you guys think it is safe if i were to put a tube in it?
1979 KZ1000ST
Last edit: 03 Jul 2011 21:40 by Brown_Muscle.
- racer54
03 Jul 2011 21:54
It would be fine with a tube. I plan on doing the same thing soon...
- testarossa
03 Jul 2011 22:30 - 03 Jul 2011 22:42
Please do put a tube in there. You have been lucky that the tire has held air and not slipped off the bead so far. Don't ride another mile before you get a tube in that tire. You loose air suddenly in that front and you're going down.
EDIT: Are you entirely sure that your tire is tube type? Bridgestone makes two versions of the BT-45. The H speed rated version requires a tube, and the V speed is tubeless. The link that you posted is for the H which would need a tube. In either case it would be fine to run a tube, and it would definitely be the safe choice IMO.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
Last edit: 03 Jul 2011 22:42 by testarossa.
03 Jul 2011 22:35
Is the sidewall marked TT (tube type) or TL (tubeless). If it is marked TT by all means install a tube. Ed
- Brown_Muscle
04 Jul 2011 12:06
It says "Tube Type" right on the sidewall, and thanks guys i will buy a new tube ASAP. I was worried I'd have to buy a new tire.
1979 KZ1000ST
- zed810
09 Jul 2011 16:50
yes you can fit tube type on tubeless wheels as long as you fit a tube the only difference between tube type and tubeless is the tubeless has a airtite membrane to hold the air in.
1981 z750e1 gpz 750a1 tank and side panels 810 bore kit web cams mikuni bs34 vance and hines pipe
