Engine guard mounts
- Archiddeon
Engine guard mounts
01 Jul 2011 19:18
Working on my '83 GPz 550 today I noticed something I hadn't before ... the mounts for the engine guards are not symmetrical between the left and right sides of the bike ... they aren't even the same. I would like to check if this is proper, or if someone did a repair to one of them at some stage. They both look like they belong, so I'm not sure.
I know the bike was dropped at some point (the left engine gaurd has a dent in it and was broken (the mount had broken off, been badly welded and broken again).
The left side (damaged side) mount for the engine guard, welded in position
The right side mount, simply bolted into position
Is the right one different to allow the engine block to be removed in that direction?
Attachment left_side_plate.jpg not found
Attachment right_side_plate.jpg not found
1983 GPz 550
1985 Honda CH150 Scooter
1995 Suzuki GS500E
1995 Suzuki GS500E
- M357.5
- Kwakas N' lots of em'
Re: Engine guard mounts
01 Jul 2011 20:08
Yep its removable on one side for exactly this reason...
The welded mount is 100% correct as is the removable mount. No worries, all is well.
83 KZ750L X2 + goodies = Project
84 KZ750L the mini ELR replica replica lol
84 ZX750E Turbo modded n' FAAAAASSSSSSTTTTT
85 GPz900r GREEN N' MEAN
The following user(s) said Thank You: Archiddeon
