Primary Chain?
  • davehayward1
  • davehayward1's Avatar Topic Author
Primary Chain?
30 Jun 2011 20:49
#460346
Starter clutch issues on my '81 KZ 750 LTD
Replaced springs and rollers and it worked fine for a while.
Pulled the starter clutch again and replaced three stripped bolts but it's still
rattling when I hit the start button
I have a replacement starter clutch and am going to replace the whole thing this time
What about the primary chain?
It looks fine - a little loose maybe. How do I know if it should be replaced?
  • SPARKY47
  • SPARKY47's Avatar
  • 1980 KZ500 B2
Re: Primary Chain?
30 Jun 2011 23:13 - 30 Jun 2011 23:14
#460380
I suspect your 750 will be similar to my 500 in that my manual says no more than 1" of up and down play in the middle of the primary chain.Problem is it being wrapped around the crank...engine out,cases split jobbee.Best of luck.
1980 KZ500 B2
Last edit: 30 Jun 2011 23:14 by SPARKY47.
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: Primary Chain?
01 Jul 2011 00:02
#460392
Replace the primary chain when you commit to a complete tear down and you wont feel so bad about the job :laugh:
Its not difficult, just time consuming.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • bountyhunter
  • bountyhunter's Avatar
Re: Primary Chain?
01 Jul 2011 03:53 - 01 Jul 2011 03:54
#460419
davehayward1 wrote: Starter clutch issues on my '81 KZ 750 LTD
Dumb question: do you mean the chain connecting the starter gear to the flywheel drive hub?
Last edit: 01 Jul 2011 03:54 by bountyhunter.
  • davehayward1
Re: Primary Chain?
04 Jul 2011 20:59
#461046
Thanks to all for the help
I replaced the starter clutch and it's running beautifully
  • steell
  • steell's Avatar
Re: Primary Chain?
05 Jul 2011 02:22
#461097
750 four, the chain connecting the crankshaft to the secondary shaft, which then spins the clutch.
  • bountyhunter
Re: Primary Chain?
05 Jul 2011 02:46 - 05 Jul 2011 02:49
#461099
OK, I thought the 81 750 LTD was a twin. It's a four.
Last edit: 05 Jul 2011 02:49 by bountyhunter.
