Are wheel seals needed ???
  • Cruez
  • Cruez's Avatar Topic Author
30 Jun 2011 01:28
#460237
When converting to sealed bearings, is there a real reason to even have the seals anymore...
I can get the bearings fairly easy, but the seals would be an additional expense. I just don't know why they would be needed anymore..
  • Motor Head
  • Motor Head's Avatar
Re: Are wheel seals needed ???
30 Jun 2011 08:53
#460255
Sure it helps keep the hub cleaner, otherwise dirt and water will be causing corrosion. Just think about how much harder it would be to get it a part if the snap ring is all rusted to the inner hub bore.
  • martin_csr
  • martin_csr's Avatar
Re: -
30 Jun 2011 10:11 - 15 Feb 2013 11:15
#460266
Last edit: 15 Feb 2013 11:15 by martin_csr.
