Fork Question
- badrhino
Fork Question
27 Jun 2011 22:18
So I got my bike up on some milk crates to take the front wheel off and what not. Decided to turn the forks just for the heck of it. When turning the handlebars left and right you can notice that the forks want to somewhat return to the center position. The triple tree turns freely and doesn't feel like there is stiction anywhere but it does seem to want to return the center position with a weird "spring back" feeling.
Does that mean my Steering head bearings are shot?:blink:
Funny thing is I did not notice this when the bike was on the ground.
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Franken Z!
- testarossa
Re: Fork Question
27 Jun 2011 23:08
Yep, sounds like your neck bearings are getting notchy. Probably a good time to convert to tapered roller style neck bearings. They are a good upgrade. You probably just have the very early stages or your neck bearings weren't very tight. That would be my guess as to why you didn't notice it on the ground.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
Re: Fork Question
28 Jun 2011 00:06
testarossa +1. Steering should be dead smooth lock to lock. Tapered roller bearings are definitely the ticket. Ed
- RonKZ650
Re: Fork Question
28 Jun 2011 00:19
Yea the bearings take a beating, the balls dig into the races and since 95% of riding you are basically pointed forward, this beating makes for a detent at straight ahead position. Does it hurt anything is the question? Well I thought it might so replaced for tapered bearings in 2 KZ650s and my KZ1000MKII. Did I notice a huge improvement? Not really. Now I ride a well worn 77 KZ650 with detent dented races and don't see need to waste time and money to repair.
- badrhino
Re: Fork Question
28 Jun 2011 00:58
I don't plan on riding it a whole bunch this summer, just trying to get it all back together finally so I can ride it for the first time. I might just replace the bearings at a later date if it is safe to run it like this for a while.
Franken Z!
Franken Z!
- mtbspeedfreak
Re: Fork Question
28 Jun 2011 03:26
Dumb question, these are tapered bearings, right?
www.z1enterprises.com/detail.aspx?ID=2780
They are tapered, so I'm thinking so. :pinch:
2000 ZRX 1100
1976 KZ 900- Daily Driver
- btchalice
Re: Fork Question
28 Jun 2011 05:10mtbspeedfreak wrote: Dumb question, these are tapered bearings, right? www.z1enterprises.com/detail.aspx?ID=2780
yep those are tapered
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
- Kidkawie
- I bleed premix
Re: Fork Question
28 Jun 2011 07:47
Are you sure a cable or brake line isnt binding up and pulling it back?
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- badrhino
Re: Fork Question
28 Jun 2011 12:20Kidkawie wrote: Are you sure a cable or brake line isnt binding up and pulling it back?
Might be, I'll check. I was wondering that myself.
Franken Z!
Franken Z!
Re: Fork Question
28 Jun 2011 15:36
when i wrecked my z1r and had it off the ground repairing it i had the same problem.
except it would damn near snap back to center.
the rollers never roll far enough to get into the next divot tho.
if you know your neck bearings are dented and you dont replace them that is your choice.
have you ever felt how a trailer with a rusty ball and hitch tries to push you around?
have any family that cares whether you go down or not?
just sayin,neck bearings are cheap.
- badrhino
Re: Fork Question
28 Jun 2011 18:19
Yeah they pretty much snap back (ever so slightly)when it gets close to the center position.
How hard is it to change them, is it a simple undo and replace?
Franken Z!
Franken Z!
Re: Fork Question
28 Jun 2011 18:21
easily done in an evening no prob.
