fork oil or sae 10-20 oil ?
- Kidkawie
- I bleed premix
Re: fork oil or sae 10-20 oil ?
23 Jun 2011 22:52mark1122 wrote: i would just use 20 fork oil. the damping in these old forks is almost none existant.
+1
These suspensions, and service manual recommendations, are prehistoric compared to todays standards. Its going to take alot more than oil to get these suspensions to perform. Im going to install the Race Tech emulators to get some sort of dampening in my suspenders.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- wireman
23 Jun 2011 23:21
30w synthetic motor oil
- otakar
24 Jun 2011 09:23wireman wrote: 30w synthetic motor oil
Is still lighter than 20W fork oil. Make sure that it is straight weight and non detergent.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- steell
24 Jun 2011 12:51mark1122 wrote: i would just use 20 fork oil. the damping in these old forks is almost none existant.
On my 79 750 twin if I were to use 20w fork oil then I'd save money just by welding the forks solid, wouldn't be much difference in ride. I weigh near 250 lbs and changed from 50% 15W/50% 10w to straight 10w because every little crack in the road was making the front end jump. It was like the forks were almost solid. Progressive springs with 10w oil and I'm not getting beat up any longer, suspension actually works.
- bountyhunter
24 Jun 2011 18:14
My 750 twin factory manual calls out 15W fork oil. That's what I am currently using and it seems right for me. I only weigh 175 and our operating temp range around here is from about 60F to 90F, so 15W works well. I tried 10W and it was a little too mushy for me.
