39mm forks in 38mm tree clamp?
- jimmyjimmyjoe
- Hope Im ready for this build
22 Jun 2011 01:16
I got a kz1000 and i cant find any kawasaki 21" front chrome rims so i may be going harley rims, plus they are cheaper.
So my 1988 kz1000 p-7 has 38mm forks do you think i could squeeze in some harley davidson 39mm forks so i could use the harley rim?
Im thinking this is the best way to go. I might could get the kz forks machined but?...
- testarossa
Re: 39mm forks in 38mm tree clamp?
22 Jun 2011 12:48
Could it be possible to lace a 21" rim to a Kawasaki hub? I'm not familiar with the spoke counts on either, but it seems easy enough to me. With all the guys who have built KZ choppers, there has to be some way to make a 21 fit that bike.
I wouldn't recommend trying to fit fork legs into triple clamps that are bored for a smaller size leg. Seems unsafe to me. I doubt that you would even be able to get the bolt started to clamp the leg if you were even able to stretch the clamp out far enough to fit a 1mm larger leg in there.
If you were dead set on using an HD front end, then get the whole front end with the triple clams, and swap a KZ stem in there.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- dutchz
22 Jun 2011 17:20
My buddy Scott laced a 21" hoop to his standard KZ1000 hub, pretty sure he ordered the spokes and rim from Buchanan's. His handle here is ssalyer but he hasn't been on for a while, try a PM.
1974 Kawasaki Z1
Stock front hub and rear axle.
22 Jun 2011 18:11
you would need to have the kz trees bored out to accept the bigger legs.
