How to adjust the belt tension
- jmdayton
07 May 2006 19:18
I am hoping that someone can help me. I have a 1983 KZ750 belt drive. It has started to squeek as I drive down the road. My guess is that I need to adjust the tension of the belt. I am not sure how to do that and I do not have the tension gauge either. Any ideas? Thanks for your time.
Melanie
Melanie
- DanOz7Five0
Re: How to adjust the belt tension
07 May 2006 19:33
If you go to
www.buykawasaki.com
and enter your bikes information (not the VIN on these old bikes you can find anything related to your bike there.
I found by looking up your bike that you have adjustment bolts at the end of your rear swingarm. Put the bike on its centerstand and at the back of the swingarm there are 2 bolts. Loosen the nut onthe axle and at the end of them and tighten the bolt at the tip of it. Make sure both sides are equal with the marks on your swingarm. Some say to measure it with a tape measure also.
If Im not mistaken you should have about 1/2" of play in the belt.
I have chains on my bikes so maybe Im way off and a squeaky belt is a sign of time for a new belt. Someone else may have a better idea of this.
