front forks
  • kzkilo
  • kzkilo's Avatar Topic Author
front forks
11 Jun 2011 02:30
#456629
hello again im sry to annoy everyone with noob questions but i appreciate the help. are there any forks that are compatible with a 1982 kz1100 shaft that might handle a little better than the stock ones. thank you
  • steell
  • steell's Avatar
Re: front forks
11 Jun 2011 11:20
#456661
Just out of curiosity, what problems are you having with the stock forks?
  • otakar
  • otakar's Avatar
Re: front forks
11 Jun 2011 11:40 - 11 Jun 2011 11:45
#456662
I am presuming that you have the leading axle fork design. Meaning that the axle is mounted to the front of the fork tube and not underneath it. This design was intended for effortless straight line highway cruising. What you require is a fork setup from a 81-82 KZ1000J. I did the same thing to my KZ1000 CSR. I had the same problem. By installing the "J" forks it made the bike handle much better. The "J" forks are a direct swap but you must also use the "J" rotors and caliper mounts. You can also use 1982-2005 police forks but you will still require the "J" or GPZ rotors and calipers.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 11 Jun 2011 11:45 by otakar.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: front forks
11 Jun 2011 12:07
#456670
You might also consider a set of drop-in Progressive springs as a replacement to the stock springs...cheap and do-able on a Saturday afternoon.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • otakar
  • otakar's Avatar
Re: front forks
11 Jun 2011 12:35
#456675
Mcdroid wrote: You might also consider a set of drop-in Progressive springs as a replacement to the stock springs...cheap and do-able on a Saturday afternoon.
An afternoon? :blink: It takes me about two hours to do a total fork rebuild. :laugh:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • kzkilo
Re: front forks
18 Jun 2011 18:57
#458068
thank you guys for the help. is there a good place to buy the "j" forks and components?
  • MFolks
  • MFolks's Avatar
Re: front forks
18 Jun 2011 19:19
#458071
I've heard/read good things about this company: www.racetech.com/page.aspx?id=56&menuid=62
