Front Sprocket ???
  • badrhino
  • badrhino's Avatar Topic Author
Front Sprocket ???
04 Jun 2011 12:09
#455343
I am converting to a 530 and took off my old 630 front sprocket and noticed it has notches for the lock nut washer on it and the new 530 sprocket does not. So what washer do I use to put it back together now? The old set up has three pieces (looks like a normal washer, and then two lock tab washers)as shown in picture.
Do I need to get a different type of washer now to bend tabs over the nut so it doesn't come loose?
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: Front Sprocket ???
04 Jun 2011 12:33
#455351
You dont need to use the lock washer without anything for it to grab onto.
In this case, I've used one washer and the bolt with success for the last several years use.
Generously use some blue thread locker and torque it down to 60 ft lbs.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
04 Jun 2011 13:48
#455381
A lot of aftermarket sprockets (junk in my opinion) don't have the indentation for the lock washer. I would definitely use a lock washer (new is prefered) and just bore a hole in the sprocket where needed. Ed
