I had a flat on my KZ 750
  • 876KZ1000A
  • 876KZ1000A's Avatar Topic Author
  • Did you bleed when you built that?
03 Jun 2011 10:20
#455156
Last night I had a flat on my 750. Luckily we had just taken off, headed home for the night. I have a nice rim from my KZ1000 in my shop with a new bridgestone spitfire. I'm pretty sure the rim is a direct bolt on but the sprocket is my concern. Are the chain sizes the same between a 1980 KZ750 and KZ1000. The motor that the 1000 rim was matched up to was a 80 or 81 MKII motor. Im going to take my compressor over there later and see if I can get it to hold air long enough to ride it the 15 blocks to my shop.
Some one told me I should buy a bunch of horses once. I bought a bunch of bikes instead.
1974 CB360T frame only, future cafe project
1975 CB360T from dealer collection, rider
1977 KZ1000A frame #2540, full resto under way
1979 CB650 stock/modified, this thing keep evolving
1980 KZ750H LTD, rider
  • btchalice
  • btchalice's Avatar
Re: I had a flat on my KZ 750
03 Jun 2011 17:59
#455216
if not the sprocket might fit
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
  • steell
  • steell's Avatar
04 Jun 2011 10:28
#455327
Both use 630 chain stock.
  • 876KZ1000A
04 Jun 2011 16:02 - 04 Jun 2011 16:08
#455399
Thanks steell. I have the bike in a safe place and tomorrow I will swap everything out. I'll pick the better of the two sprockets and I should be in there.
this is the sprocket from my KZ1000
Attachment IMG_1403.JPG not found
and a look at the tire
Attachment IMG_1412.JPG not found
Last edit: 04 Jun 2011 16:08 by 876KZ1000A.
  • 876KZ1000A
12 Jun 2011 16:27
#456853
The wheel swap won't work. The axle diameters are different. The 1980 KZ750 axle diameter is 18mm. The 19?? KZ1000 axle diameter is 20mm. I guess I'll swap out the tires, which ARE the same size.
130/90 16.
  • 876KZ1000A
14 Jun 2011 12:49
#457230
took the wheels to ccyle specialists in western hills yesterday. Im going to pick them up around 2 today. I have all of the little parts degreased and Ill be putting it all back together tonight once the heat subsides a bit.
  • 876KZ1000A
16 Jun 2011 12:05
#457602
Another two wheel happy ending. I had the BT45 swapped out for the Spitfire, a bit of a downgrade but I'm glad the tire is going to get used. I paid $56.68 for the swap out and a new valve stem, a bit pricey but worth it in light of the fact that I really trust Rob and the guys in the service department there. I rarley have others do my wrenching and when I do it's usually a huge disappoinment. I remounted the rear wheel and my 4 into 2 stock exhaust yesterday with a wicked hangover. The shop manual was helpful but far from a step by step guide. It doesn't mention things like the fact that you have to drop the exhaust to get to the axle nut.
I really fought with the exhaust and getting all 8 collars resting precariously in place while I bolted it all back in place. And before someone mentions it yes I know that it all comes apart and that makes it easier to reassemble but somewhere in there was a can of worms waiting for me to strip a bolt or nut etc. I took the briefest test ride in a pin point size downpour without my helmet. Cold wet ouch hurts.....
The rain stopped and I was able to give it a proper run last night. In the long run I think I had two issues that were sorted out by swapping out the wheel.
1) I think the rear wheel wasn't on nice and straight. It didnt spin nice and free before I took it off, half of a rotation and that was it. I line up the alighnment marks, then I look at the chain and use a straight edge to check that its not getting bent or bound by a misaligned sprocket. Then my last test is wheel spin. I spin the wheel with the bike in neutral and if I dont get at least two full rotations I look for something like a bad bearing or a stuck caliper. If im in the ball park spin wise but still under two rotations I tweak the slack adjusters until it spins freely. Then I recheck the chain with a straight edge.
2) I had a tiny exhaust leak on cylinder 3. I suspected this before the whole flat tire issue. I could hear that something sounded a tiny bit louder on the right side as I was riding. Once it was all together and I fired it up it sounded completely different. Smoother than the smooth it already was.
  • martin_csr
  • martin_csr's Avatar
Re: -
16 Jun 2011 12:57 - 15 Feb 2013 10:12
#457603
Last edit: 15 Feb 2013 10:12 by martin_csr.
  • RonKZ650
  • RonKZ650's Avatar
17 Jun 2011 01:09
#457729
Yea, there's no Kawasaki I know of that needs the exhaust fooled with to remove the wheel. So some unnessessary work done. Another thing, anyone has a flat tire and you are a few miles from your destination, just ride. A few times I've been in more or less slumsville and thought riding on a flat at 2am beat the alternative. Give it a try. I started riding at like 20mph and finally just rode 40 or so. No big deal. The tire will get hot so you can't ride like 50 miles this way, but less than 10 I just ride. This is coming from probably the most "professional" flat tire motorcycle rider around I know of. Over the years I've been hit with 50 or more flat tires.
  • 876KZ1000A
17 Jun 2011 15:23
#457796
RonKZ650 wrote: Yea, there's no Kawasaki I know of that needs the exhaust fooled with to remove the wheel. So some unnessessary work done. Another thing, anyone has a flat tire and you are a few miles from your destination, just ride. A few times I've been in more or less slumsville and thought riding on a flat at 2am beat the alternative. Give it a try. I started riding at like 20mph and finally just rode 40 or so. No big deal. The tire will get hot so you can't ride like 50 miles this way, but less than 10 I just ride. This is coming from probably the most "professional" flat tire motorcycle rider around I know of. Over the years I've been hit with 50 or more flat tires.
No thanks. I'm not fond of the idea of ruining a rim and endangering a passenger just for the convenience of not walking a few blocks.
As far as the exhaust is concerned, it had to drop down. Sittng on the center stand the tire is approx 2 1/2" off the ground. If I dropped the swing arm the axle nut would have been square in the middle of the exhaust. If my jackstand had been empty yes that would have worked.
As far as torquing the axle nut is concerened, they are specs, not suggestions and they are not to be ignored for the sake of convenience.
I appreciate the input regardless.
  • RonKZ650
  • RonKZ650's Avatar
17 Jun 2011 16:04
#457809
Of course if you want to torque the bolt to spec you did the only way, however the way to do it without removing the wheel is to loosen the axle, loosen your 2 chain adjusters on the swingarm to full loose, remove the bolt on top of the end of each side of the swingarm and remove the stopper from each end of the swingarm. Now push the wheel forward, slip the chain off the sprocket and you slide the whole wheel/axle combo off the back. Of course you need to unbolt any arm that goes to the rear brake too. After the wheel slides out the back it should fall low enough to allow the axle to be removed then. If not than another option is setting your centerstand on a piece of plywood or something to bring the tire up off the ground a little extra. Of course if you want to torque the axle which is a waste of time you can remove the pipes. About the walking, I'm not too lazy to walk, I walk 20 miles or more a week, but been in places I prefer not to walk in certain areas of the country, get mugged, get the bike stolen or vandalized. Any number of things and riding a few miles on a flat can at certain times be the better choice. You did fine doing it your way, just want to mention there are other ways to do it. I wouldn't remove the exhaust to remove the wheel myself.
