another rookie mistake....grrrrr
- dynastydudge
02 Jun 2011 20:28 - 02 Jun 2011 21:33Attachment grr.jpg not found
i was changing the rear wheel bearings on my 1980 kz 750 h1. I put one side in and ofcourse started to put the other side in and forgot to put the spacer that goes in between the bearings in. so i was beating out the one side with a chisel from the other side, and i booger up the rim as shown in the picture. Is this rim any good still? I need some opinions on this one guys please. man i hope i dont have to buy a new rim.
were not here for a long time, just a good time......1980 kz750 ltd h1
1982 honda cm 450e
1982 honda cm 450e
Last edit: 02 Jun 2011 21:33 by dynastydudge.
- wireman
Re: another rookie mistake....grrrrr
02 Jun 2011 20:52
why did you have to put the axle bolt in before installing new bearing?
- dynastydudge
02 Jun 2011 21:32 - 02 Jun 2011 21:34
im sorry wireman....meant the spacer that goes in between the bearings inside the hub that the axle slides thru. i edited the post.
1982 honda cm 450e
1982 honda cm 450e
Last edit: 02 Jun 2011 21:34 by dynastydudge.
- wireman
02 Jun 2011 21:37
ah
- btchalice
02 Jun 2011 23:04
if its only the chips that seem to be what i see i wouldnt be scared to use it. if its worse than it looks i might have a 16" like it in the garage
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
- silverado
03 Jun 2011 00:02
If it helps i have a couple of 16" rims off a 550 ltd.
1980 kz 650 f
2 1981 kz550 ltd's
1 19?? kz750
2 1981 kz550 ltd's
1 19?? kz750
Last edit: 15 Feb 2013 10:05 by martin_csr.
03 Jun 2011 09:54
Not trying to be a wise guy, but next time use one of these instead of a chisel; much less chance of damaging anything:
cgi.ebay.com/Punch-Brass-Drift-/22079245...&hash=item33684171c0
- pugeyed
03 Jun 2011 14:02
i agree, brass drift all the way
kz750 h3 1982 4cl
- dynastydudge
03 Jun 2011 21:33 - 03 Jun 2011 22:01
im gonna try the rim....thanks for the replies....and rim offers
1982 honda cm 450e
1982 honda cm 450e
Last edit: 03 Jun 2011 22:01 by dynastydudge.
