Clubman vibration damper
  • XL777
  • XL777's Avatar Topic Author
02 Jun 2011 14:52
#454977
I have 7/8 clubmans from z1e and after about 30 min of riding my arms are already numb from viration. Anyone recommend a good damper?
2012 Triumph Bonneville SE black
1978 KZ1000 B2 LTD
Fresh top end rebuild
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
It is easier to say what I haven't replaced then what I have.
I must love this cruel mistress since she hates me
  • Motor Head
  • Motor Head's Avatar
Re: Clubman vibration damper
02 Jun 2011 15:16
#454980
Sorry no, but why the vibration? They all do some, but is yours excessive. Even cylinder compression, and the carbs synched good? Nothing loose, like motor mount bolts? Bad drive chain?
  • MFolks
  • MFolks's Avatar
02 Jun 2011 15:34
#454983
Look here: www.barsnake.com/ Other riders have had success by filling the hollow handlebars with the black RTV compound. I suppose a RTV like caulking compound would work too. Just make sure it's not the adhesive/sealant as it sets up hard and would not work.
  • hocbj23
  • hocbj23's Avatar
02 Jun 2011 15:45
#454985
Look on Ebay for bar end weights from an 86-90 Yamaha Radian.7/8 inch dia. fit,,long and with rubber grommets on the ends.They should do the trick and can usually be found cheap.bj
  • XL777
02 Jun 2011 22:47
#455083
I picked up a set at the local shop bar end type kinda small though. I'll try en out for 20 bucks.
The vibrations seem no different then normal. But I will double check my mounts since the engine was out
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
  • XL777
04 Jun 2011 13:21
#455373
Bar end ones seem to have cut vibs down by 60% :) added an emgo cafe fairing as well. It is ok but I find it pushes the wind right into my face.
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
  • kawasakispeedin
  • kawasakispeedin's Avatar
07 Jun 2011 22:55
#456024
XL777 wrote: Bar end ones seem to have cut vibs down by 60% :) added an emgo cafe fairing as well. It is ok but I find it pushes the wind right into my face.
i have a set of woodcraft clip-on's and have more vibration than id like also. i was wonderring what you found for bar-ends?
-1980 Kz1000 ltd (current)
-1993 Suzuki GSX600F
-2006 ZZR600 (past)
-1981 GPz550 (past)
